[mapserver-users] problem map server 5.0.2 installation
Jimmy Nimo
jimmy.nimo at pranical.com
Thu Apr 3 14:57:31 EDT 2008
hello to all.
I have a problem trying to install mapserver 5.0.2 in a IA64
architecture, i'm using Red Hat Enterprise Linux ES release 4 (Nahant
Update 3) in a HP rx2620. first, I'm making every package from
scratch, I try with apache 2.2.8 and php 5.2.5, let me show the
configure parameters for each package.
Apache 2.2.8
./configure --prefix=/usr/local/apache2 --enable-deflate
--enable-info --enable-mime-magic --enable-rewrite --enable-so
--enable-speling --enable-ssl --enable-unique_id --enable-usertrack
--with-mpm=prefork --with-apxs2 --with-apr=/usr/local/apr-httpd
--with-apr-util=/usr/local/apr-util-httpd
php 5.2.5
./configure --prefix=/usr/local/apache2/php
--with-apxs2=/usr/local/apache2/bin/apxs
--with-config-file-path=/usr/local/apache2/php --with-openssl
--with-kerberos --with-zlib --with-bz2 --with-curl
--with-gd=/usr/local/ --with-pgsql --with-xsl --with-gettext
--with-regex=system --with-unixODBC=/usr/ --without-pear
and then i put mapserver 5.0.2 from scratch, this are the parameters:
./configure --with-proj=/usr/local
--with-geos=/usr/local/bin/geos-config
--with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config
--with-curl-config=/usr/bin/curl-config
--with-httpd=/usr/local/apache2/bin/httpd
--with-php=/usr/local/apache2/php/ --with-wfs --with-wfsclient
--with-wmsclient --enable-debug
--with-curl-config=/usr/bin/curl-config --with-threads --with-wcs
--with-wcsclient --with-sos --with-gd=/usr/local/ --with-freetype
--with-jpeg=/usr/include --with-png=/usr/include
i put the mapserv in the cgi-bin carpet and it work, my problem start
with the mapscript library for php, when i try to load the library it
put a segmentation fault in the error.log
[Thu Apr 03 18:44:38 2008] [notice] child pid 14983 exit signal
Segmentation fault (11)
but when i try to use the cgi it work, i don't know what can be the
problem, if anyone could help me it will help me a lot
thanks for reading this
Jimmy Nimo Especialista TI
Pranical Technologies
Cel.: +58.412.922.2505
Ofic.:+58.212.263.8275
Ofic.:+58.212.264.0710
GMail: jimmy.nimo at gmail.com
www.pranical.com
** USO DEL CORREO ELECTRONICO DE PRANICAL TECHNOLOGIES HACIA INTERNET **
Este mensaje es privado y confidencial, y está dirigido exclusivamente a sus
destinatarios. Si usted recibió este mensaje por error, debe abstenerse de
usarlo en cualquier sentido. Asimismo, le agradecemos comunicarlo al remitente
o a soporte at pranical.com y borrarlo, así como cualquier documento adjunto.
Cualquier opinión contenida en este mensaje pertenece únicamente al autor
remitente y no representa necesariamente la opinión de Pranical Technologies.
Eventualmente, los correos electrónicos pueden ser alterados o llegar
incompletos. Al respecto, Pranical Technologies no se hace
responsable por los
defectos u omisiones que pudieran afectar al mensaje original, con
motivo de su
envío por correo electrónico.
