[mapserver-users] Problem with polygons
Kamen Rider
kamenriderichigo at gmail.com
Fri Apr 4 15:02:45 EDT 2008
Sorry, but I must insist. I hope someone could help me.
---------- Forwarded message ----------
Date: 26-mar-2008 9:51
Subject:
To: mapserver-users at lists.osgeo.org
Hello,
I need something specific: To draw polygons (parcels) over a SHP map, and
none of the examples I found on the web worked.
Also I have no problems displaying points and I'm using UTM coordinates.
This is what I did:
1.- Compiled MS on Linux (CentOS) and Install.
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=SOS_SERVER
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=MYGIS INPUT=SHAPEFILE
2.- Installed MySql.
3.- Created a table on MySql to store polygons. Here is the description.
This table is called "prueba"
| Field | Type | Null | Key | Default | Extra |
| NUM | int(11) | YES | | NULL | |
| ID | int(11) | YES | | NULL | |
| poligono | text | YES | | NULL | |
This is what inserted on field poligono:
POLYGON((350000 6270000,350000 6275000,360000 6275000,360000 6270000,350000
6270000))
4.- Then created a OVF file, according to this example. (aqidata.ovf)
http://www.dottedeyes.com/web_mapping/blog/2008/02/06/how-to-display-polygons-from-non-spatial-databases/
This is my OVF file :
<OGRVRTDataSource>
<OGRVRTLayer name="aqidata">
<SrcDataSource>MYSQL:test,user=root,password=xxxxx,host=localhost,port=3306,tables=prueba</SrcDataSource>
<SrcSQL>select NUM, ID, poligono from prueba</SrcSQL>
<FID>ID</FID>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding="WKT" field="poligono"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Using OGRINFO I Tested the connection, this is the result:
INFO: Open of `/var/www/cgi-bin/tests/aqidata.ovf'
using driver `VRT' successful.
Layer name: aqidata
Geometry: Polygon
Feature Count: 1
Layer SRS WKT:
(unknown)
NUM: Integer (11.0)
poligono: Binary (0.0)
OGRFeature(aqidata):1
NUM (Integer) = 1
ID (Integer) = 1
poligono (Binary) =
504F4C59474F4E282833353030303020363237303030302C333530303030203632373530...
5.- Then a created a MAP file:
MAP
NAME "Testing"
EXTENT -177773.12 6409691.13 525065 6511086
#IMAGETYPE JPEG
#IMAGETYPE PNG24
IMAGETYPE PNG
IMAGECOLOR 255 255 255
STATUS ON
SIZE 400 400
FONTSET "fonts.txt"
SYMBOLSET "symbols.txt"
WEB
METADATA
"key1" "value1"
"key2" "value2"
"key3" "value3"
"key4" "value4"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "POLIGONO"
DEBUG ON
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CONNECTIONTYPE OGR
CONNECTION "aqidata.ovf"
DATA "aqidata"
CLASS
NAME "MyClass"
STYLE
COLOR 0 0 0
OUTLINECOLOR 255 0 0
SIZE 8
END
END
END
END
It doesn't show anything, just a white rectangle. Not even an error.
But when I display just points it works fine (using "PointsFromColumns").
I hope you could help me.
Thanks,
Pablo Molina S.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080404/bd359450/attachment.html
