[mapserver-users] Problem with polygons
Fawcett, David
David.Fawcett at state.mn.us
Fri Apr 4 15:14:31 EDT 2008
There may be greater issues, but your extent line looks wrong.
It should be: minx miny maxx maxy
Yours looks like miny maxy minx maxx?
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Kamen
Rider
Sent: Friday, April 04, 2008 2:03 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Problem with polygons
Sorry, but I must insist. I hope someone could help me.
---------- Forwarded message ----------
Date: 26-mar-2008 9:51
Subject:
Hello,
I need something specific: To draw polygons (parcels) over a SHP
map, and none of the examples I found on the web worked.
Also I have no problems displaying points and I'm using UTM
coordinates.
This is what I did:
1.- Compiled MS on Linux (CentOS) and Install.
MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=SOS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=MYGIS
INPUT=SHAPEFILE
2.- Installed MySql.
3.- Created a table on MySql to store polygons. Here is the
description. This table is called "prueba"
| Field | Type | Null | Key | Default | Extra |
| NUM | int(11) | YES | | NULL | |
| ID | int(11) | YES | | NULL | |
| poligono | text | YES | | NULL | |
This is what inserted on field poligono:
POLYGON((350000 6270000,350000 6275000,360000 6275000,360000
6270000,350000 6270000))
4.- Then created a OVF file, according to this example.
(aqidata.ovf)
http://www.dottedeyes.com/web_mapping/blog/2008/02/06/how-to-display-pol
ygons-from-non-spatial-databases/
This is my OVF file :
<OGRVRTDataSource>
<OGRVRTLayer name="aqidata">
<SrcDataSource>MYSQL:test,user=root,password=xxxxx,host=localhost,port=3
306,tables=prueba</SrcDataSource>
<SrcSQL>select NUM, ID, poligono from prueba</SrcSQL>
<FID>ID</FID>
<GeometryType>wkbPolygon</GeometryType>
<GeometryField encoding="WKT" field="poligono"/>
</OGRVRTLayer>
</OGRVRTDataSource>
Using OGRINFO I Tested the connection, this is the result:
INFO: Open of `/var/www/cgi-bin/tests/aqidata.ovf'
using driver `VRT' successful.
Layer name: aqidata
Geometry: Polygon
Feature Count: 1
Layer SRS WKT:
(unknown)
NUM: Integer (11.0)
poligono: Binary (0.0)
OGRFeature(aqidata):1
NUM (Integer) = 1
ID (Integer) = 1
poligono (Binary) =
504F4C59474F4E282833353030303020363237303030302C333530303030203632373530
5.- Then a created a MAP file:
MAP
NAME "Testing"
EXTENT -177773.12 6409691.13 525065 6511086
#IMAGETYPE JPEG
#IMAGETYPE PNG24
IMAGETYPE PNG
IMAGECOLOR 255 255 255
STATUS ON
SIZE 400 400
FONTSET "fonts.txt"
SYMBOLSET "symbols.txt"
WEB
METADATA
"key1" "value1"
"key2" "value2"
"key3" "value3"
"key4" "value4"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "POLIGONO"
DEBUG ON
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CONNECTIONTYPE OGR
CONNECTION "aqidata.ovf"
DATA "aqidata"
CLASS
NAME "MyClass"
STYLE
COLOR 0 0 0
OUTLINECOLOR 255 0 0
SIZE 8
END
END
END
END
It doesn't show anything, just a white rectangle. Not even an
error.
But when I display just points it works fine (using
"PointsFromColumns").
I hope you could help me.
Thanks,
Pablo Molina S.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080404/fab41092/attachment-0001.html
