[mapserver-users] using gdalinfo.exe
Frank Warmerdam
warmerdam at pobox.com
Tue Apr 8 22:25:10 EDT 2008
Ken S. Elvehjem wrote:
> Hi,
> I'm currently generating a query from my software to access a MrSid file
> that I have on my MapServer; here's the link:
> http://206.183.188.202/cgi-bin/mapserv.exe?map=c:\ms4w\Apache\htdocs\SD\mccook-wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=NAIP2006&STYLES=&SRS=EPSG:4269&BBOX=611300,4815500,613300,4817500&WIDTH=800&HEIGHT=800&FORMAT=image/jpeg
> <http://206.183.188.202/cgi-bin/mapserv.exe?map=c:\ms4w\Apache\htdocs\SD\mccook-wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=NAIP2006&STYLES=&SRS=EPSG:4269&BBOX=611300,4815500,613300,4817500&WIDTH=800&HEIGHT=800&FORMAT=image/jpeg>
> I'd like to be able to generate a URL that will get me the "gdalinfo" on
> that file... Here's what doesn't work:
> http://206.183.188.202/cgi-bin/gdalinfo.exe?c:\ms4w\Apache\htdocs\SD\mccook\mccook2006.sid
> Could someone point out A.) if I'm barking up the wrong tree
> completetely, and if not, B.) what does that kind of query/URL need to
> look like?
Ken,
I'm not aware of anyone doing anything quite like this. gdalinfo isn't
setup to be used as a cgi, and doesn't return things html encoded or
with a content-type header. And MapServer does not have an equivelent
functionality.
But, in theory, you could write a little gdalinfo script in php/perl/python
that would execute gdalinfo on a passed argument filename and then return
the result with a proper "Content-type: text/plain" header.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
