[mapserver-users] Getting a WMS service up and running from shape
data
Barend Kobben
kobben at itc.nl
Wed Apr 9 08:27:05 EDT 2008
I cannot test your URI as the server is unknown (cannot be pinged either:
'cannot resolve host').
But at first sight it seems you might be mistaking the projection. The
EPSG:4326 you have is a well-knownnon-projected lat-lon on the WGS84, but
epsg:42304 is not an official EPSG code AFAIK (the list goes to 32768), so
that means it's either a custom projection or you might be making a mistake
here. ...
Barend Köbben
International Institute for Geo-Information
Sciences and Earth Observation (ITC)
PO Box 6
7500AA Enschede, The Netherlands
+31 (0)53 4874253
On 09-04-08 12:56, "Lid Sjur Ringheim" <sjur.ringheim.lid at imr.no> wrote:
> Hi,
> I have currently compiled and installed Mapserver 5.0.2 and are trying
> to set up a WMS service on it. I got the demo working but are now having
> problems getting my own shape files rendrered, the only output I get is
> a white picture.
> You can get the capabilities file here
> http://talos.nodc.no/cgi-bin/mapserv?map=wms/sonate.map&SERVICE=WMS&VERS
> ION=1.1.1&REQUEST=GetCapabilities
> The Map file im using looks like this:
> MAP
> NAME SONATE
> STATUS ON
> SIZE 600 600
> EXTENT 388107.6334400378 5203120.88405952 500896.339019834
> 5310243.30613897
> UNITS METERS
> SHAPEPATH "/var/www/wmsdata/sonate"
> IMAGECOLOR 255 255 255
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> WEB
> METADATA
> WMS_TITLE "sonate"
> WMS_ONLINERESOURCE
> "http://talos.nodc.no/cgi-bin/mapserv?map=wms/sonate.map"
> WMS_SRS "epsg:4326 epsg:42304"
> #north pole stereographic
> END
> LOG "/var/www/cgi-bin/test.log"
> END
> LAYER
> NAME hvalross
> TYPE POLYGON
> DATA hvalross/hvalross_utbredelse
> STATUS OFF
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END
> METADATA
> WMS_TITLE "Hvalross"
> WMS_SRS "epsg:4326"
> END
> CLASS
> NAME DYREGRUPPE
> DEBUG ON
> STYLE
> COLOR 255 0 255
> OUTLINECOLOR 255 0 0
> END
> END
> #DUMP TRUE
> END
> END
> But when I try to render the map all I get is a white picture. The shape
> file im trying to render contains polygons with a WGS84 (North Pole
> Stereographic) projection.
> Do anyone have a tip as to where I should be looking to get more
> information about this problem/know what might be wrong?
> Best Regards
> Sjur
> mapserver-users at lists.osgeo.org
International Institute for Geo-Information Science and Earth Observation (ITC)
Chamber of Commerce: 410 27 560
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
