[mapserver-users] Getting a WMS service up and running from
shape data
Hulbert, Brian
brian.hulbert at linquest.com
Wed Apr 9 08:15:17 EDT 2008
I think you need to set the status of your hvalross layer to ON
LAYER
NAME hvalross
TYPE POLYGON
DATA hvalross/hvalross_utbredelse
STATUS ON
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lid Sjur
Ringheim
Sent: Wednesday, April 09, 2008 6:57 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Getting a WMS service up and running from shape
data
I have currently compiled and installed Mapserver 5.0.2 and are trying to
set up a WMS service on it. I got the demo working but are now having
problems getting my own shape files rendrered, the only output I get is a
white picture.
You can get the capabilities file here
http://talos.nodc.no/cgi-bin/mapserv?map=wms/sonate.map
<http://talos.nodc.no/cgi-bin/mapserv?map=wms/sonate.map&SERVICE=WMS&VERSION
=1.1.1&REQUEST=GetCapabilities>
&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
The Map file im using looks like this:
MAP
NAME SONATE
STATUS ON
SIZE 600 600
EXTENT 388107.6334400378 5203120.88405952 500896.339019834
5310243.30613897
UNITS METERS
SHAPEPATH "/var/www/wmsdata/sonate"
IMAGECOLOR 255 255 255
PROJECTION
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
END
WEB
METADATA
WMS_TITLE "sonate"
WMS_ONLINERESOURCE
"http://talos.nodc.no/cgi-bin/mapserv?map=wms/sonate.map"
WMS_SRS "epsg:4326 epsg:42304" #north
pole stereographic
END
LOG "/var/www/cgi-bin/test.log"
END
LAYER
NAME hvalross
TYPE POLYGON
STATUS OFF
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
METADATA
WMS_TITLE "Hvalross"
WMS_SRS "epsg:4326"
END
CLASS
NAME DYREGRUPPE
DEBUG ON
STYLE
COLOR 255 0 255
OUTLINECOLOR 255 0 0
END
END
#DUMP TRUE
END
END
But when I try to render the map all I get is a white picture. The shape
file im trying to render contains polygons with a WGS84 (North Pole
Stereographic) projection.
Do anyone have a tip as to where I should be looking to get more information
about this problem/know what might be wrong?
Best Regards
Sjur
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080409/1d6ecc4a/attachment.html
