[mapserver-users] using gdalinfo.exe
Ken S. Elvehjem
elvehjem at runestone.net
Wed Apr 9 08:21:54 EDT 2008
Frank,
Thank you for the response. Is there some other way to get some of the
"gdal info" with a simple query? I'm not stuck on using gdalinfo... it
just seemed like a good idea.
What I need is the UTM Zone -- that's already specified (I guess) in the
EPSG statement in the mapfile. Can it be extracted from there over the web
by way of a URL / query?
Ken
----- Original Message -----
To: "Ken S. Elvehjem" <elvehjem at runestone.net>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Tuesday, April 08, 2008 9:25 PM
Subject: Re: [mapserver-users] using gdalinfo.exe
> Ken S. Elvehjem wrote:
>> Hi,
>> I'm currently generating a query from my software to access a MrSid file
>> that I have on my MapServer; here's the link:
>> http://206.183.188.202/cgi-bin/mapserv.exe?map=c:\ms4w\Apache\htdocs\SD\mccook-wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=NAIP2006&STYLES=&SRS=EPSG:4269&BBOX=611300,4815500,613300,4817500&WIDTH=800&HEIGHT=800&FORMAT=image/jpeg
>> <http://206.183.188.202/cgi-bin/mapserv.exe?map=c:\ms4w\Apache\htdocs\SD\mccook-wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=NAIP2006&STYLES=&SRS=EPSG:4269&BBOX=611300,4815500,613300,4817500&WIDTH=800&HEIGHT=800&FORMAT=image/jpeg>
>> I'd like to be able to generate a URL that will get me the "gdalinfo" on
>> that file... Here's what doesn't work:
>> http://206.183.188.202/cgi-bin/gdalinfo.exe?c:\ms4w\Apache\htdocs\SD\mccook\mccook2006.sid
>> Could someone point out A.) if I'm barking up the wrong tree
>> completetely, and if not, B.) what does that kind of query/URL need to
>> look like?
> Ken,
> I'm not aware of anyone doing anything quite like this. gdalinfo isn't
> setup to be used as a cgi, and doesn't return things html encoded or
> with a content-type header. And MapServer does not have an equivelent
> functionality.
> But, in theory, you could write a little gdalinfo script in
> php/perl/python
> that would execute gdalinfo on a passed argument filename and then return
> the result with a proper "Content-type: text/plain" header.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
