[mapserver-users] using gdalinfo.exe
Ken S. Elvehjem
elvehjem at runestone.net
Wed Apr 9 10:22:58 EDT 2008
OK,
I'll check it out.
Thanks once again for the timely reply!
Ken
----- Original Message -----
To: "Ken S. Elvehjem" <elvehjem at runestone.net>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Wednesday, April 09, 2008 9:22 AM
Subject: Re: [mapserver-users] using gdalinfo.exe
> Ken S. Elvehjem wrote:
>> Frank,
>> Thank you for the response. Is there some other way to get some of the
>> "gdal info" with a simple query? I'm not stuck on using gdalinfo... it
>> just seemed like a good idea.
>> What I need is the UTM Zone -- that's already specified (I guess) in the
>> EPSG statement in the mapfile. Can it be extracted from there over the
>> web by way of a URL / query?
> Ken,
> There is no stock mechanism for this, but you could write a custom
> mapscript application to pick this information out of the map file and
> return it as a web service. I would note though that MapServer does not
> normally provide access to stuff like file bounds to mapscript so there
> it is hard to provide very much information using mapscript itself.
> You could try setting up the dataset as WCS accessable, and then the
> WCS DescribeCoverage method would provide a variety of information about
> the file.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
