[MAPSERVER-USERS] SLD ignored / External Graphic ignored
Sicky
Christian.Rueh at rostock.zgdv.de
Thu Apr 10 08:49:00 EDT 2008
Hi Barend!
Thanks, this solved my problem! :-)
I knew it was fairly easy, but you find so much about that topic.....
And great that there will be an error message implemented. It's annoying
when you have something which clearly doesn't work but you have absolutely
no idea why it isn't working....
@Yewondwossen: Is there any planning on supporting SVGs as ExternalGraphics?
If so, please make it better than in GeoServer:
http://sicky.i-networx.de/temp/geoserv/geoserv_svg_probs.png
Barend Köbben wrote:
> Hi,
> I never tried the external SVG graphics, but the SLD problem sounds very
> familiar. Almost always I find this kind of problem having not much to do
> with the SLDs themselves, but with TMP file settings. This is certainly
> more
> likely if you say sending the SLD it in SLD-BODY works.
> Using SLDs is dependent on the correct setting of the two settings
> IMAGEPATH -- where the mapserver software puts the SLD and other
> temporary
> files
> IMAGEURL -- where the web browser and other http services pick them up.
> Setting these incorrectly, and more importantly their security setting
> incorrrectly, will normally give no problems, but when using SLDs (and
> also
> in other cases, eg. when chaining Mapserver to external WMS and WFS
> services), they will make MS malfunction, but SILENTLY (ie. No error
> messages).
> Eg. in our set ups of a WMS with external SLD they are set as follows:
> For a *nix setup ( MacOSX) with Mapserver CGI 'behind' Apache:
> WEB
> IMAGEPATH "/Users/kobben/Sites/ms_tmp/"
> IMAGEURL "http://localhost/~kobben/ms_tmp/"
> METADATA
> [all your web metadata...]
> END #metadata
> END #web
> For a Win box with Mapserver CGI 'behind' IIS:
> IMAGEPATH "C:/tmp/ms_tmp/"
> IMAGEURL "http://geoserver.itc.nl/ms_tmp/"
> The IMAGEPATh is a directory that is reacheable by Mapserver at this real
> location (in this case expressed as Unix BSD path on my MacOSX or as UNC
> path on Win) and that has read & write access set for the Mapserver
> process. Eg. on the Winbox it should have write access for the anonymous
> system service account under which Mapserver runs (usually something like
> SERVERNAME\IWAM_SERVERNAME).
> You can test this by seeing if files with names like) are being created
> when
> you request the WMS with external SLD. If they are the IMAGEPATH celarly
> works. Then test if you can point a browser to the IMAGEURL and pick up
> the
> tmp file. If that worsk the IMAGEURL is also OK. Now it should work...
> Hope this helps.
> International Institute for Geo-Information Science and Earth Observation
> (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for
> the addressee only. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or action in relation
> to the content of this information is strictly prohibited. If you have
> received this e-mail by mistake, please delete the message and any
> attachment and inform the sender by return e-mail. ITC accepts no
> liability for any error or omission in the message content or for damage
> of any kind that may arise as a result of e-mail transmission.
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/SLD-ignored---External-Graphic-ignored-tp16586209p16608571.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
