[mapserver-users] JGW+JPG -> TIFF
Carlo Pelliconi
c.pelliconi at sis-ter.it
Thu Apr 10 09:48:46 EDT 2008
Hi.
If you create a layer in the mapfile, with DATA set to your-raster.jpg,
it automatically reads .jgw (it must have the same name of the jpg file)
and users its informations for georeferencing it. Specify also TYPE
raster and if you want MIN/MAXSCALE.
If you prefer tiff file, you must convert jpg in tif by means of a
graphic editor and then translate .jgw in .tfw. It could request not
only renaming the file, but also modify some coefficients defined inside
the .jgw file (open it with notepad, it is simple text).
Hope this helps.
Bye
Janosch.Skrobek at trier.de ha scritto:
> Hello,
> I have a set of orthophotos which are saved as JPG. Each picture has a
> corresponding JGW file. Can I somehow implement these into a mapserver
> layer? Or do I need to create georeferenced tiffs? If so, how can I
> combine the JGW and JPGs into a tiff?
> Thank you
> Janosch
> Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
> informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail. Das unerlaubte
> Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet. Der
> rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier ist über diese
> E-Mail-Adresse derzeit noch nicht möglich.
> mapserver-users at lists.osgeo.org
ing. Carlo Pelliconi
SIS.TER S.p.A.
www.sis-ter.it
via Mentana, 10
40026 Imola (BO) Italy
cell +39 333 6375379
tel +39 0542 364034
fax +39 0542 612130
ATTENZIONE!
Questo documento è indirizzato esclusivamente al destinatario. Tutte le
informazioni ivi contenute, compresi eventuali allegati, sono soggette
a riservatezza secondo i termini del D.Lgs. 196/2003 in materia di
"privacy" e ne è proibita l'utilizzazione da parte di altri soggetti. Si ricorda che la diffusione l'utilizzo e/o la conservazione dei dati ricevuti per errore costituisce violazione di carattere penale ai sensi dell'art. 616 Codice penale (Violazione, sottrazione e soppressione di corrispondenza). Se avesse ricevuto per errore questo messaggio, La preghiamo cortesemente di contattare il mittente al più presto e di cancellare il messaggio subito dopo. Grazie.
ATTENTION!
This message is being sent from Sis.Ter S.p.A. and may contain information which is confidential or privileged. If you are not the intended recipient, please advise the sender immediately by reply e-mail and delete this message and any attachments without retaining a copy. Any unauthorized use of the content of this message is a breach of your duty to respect the confidentiality of the correspondence between other persons and can expose the responsible party to civil and/or criminal penalties (D.Lgs. 196/2003 "Tutela della privacy" e art. 616 Codice penale "Violazione, sottrazione e soppressione di corrispondenza"), and may constitute a more serious offence. Thanks.
ACHTUNG!
Dieses Dokument ist ausschließlich dem Empfänger vorbehalten. Die darin enthaltenen Informationen, auch jene in etwaigen Anlagen, gelten im Sinne des Dekrets Nr. 196/2003 in Sachen "Privacy" als streng vertraulich und dürfen von anderen Personen nicht verwende werden. Wer diese Mitteilung irrtümlicherweise erhält ist gebeten uns umgehend zu informieren und anschließend die Mitteilung zu vernichten. Vielen Dank.
