[mapserver-users] ms4w mapserver 5.0 can't display raster image.
ptang83 at yahoo.com
Sun Apr 13 23:40:35 EDT 2008
I used Mapserver + Openlayers + Postgis. I can load shp data to postgis and display it without any problem. However, somehow I am not able to display any raster map even without using postgis. I only see a blank rectangular on my web browzer. I wonder whether there is a bug or something I did wrong. Thanks in advance..
I have downloaded ms4w Mapserver and has the following config.
# Apache 2.2.8
# PHP 5.2.5
# mapserv 5.0.2 at /cgi-bin/mapserv.exe
LOG files show nothing wrong:
Sun Apr 13 21:57:14 2008,12804,127.0.0.1,nitelti020l,3,-0.000000 -90.000000 180.000000 90.000000,-1.000000 -1.000000,,normal execution
Sun Apr 13 21:57:14 2008,14076,127.0.0.1,nitelti020l,3,-180.000000 -90.000000 0.000000 90.000000,-1.000000 -1.000000,,normal execution
MAP file:
# Map file created from QGIS project file C:/Program Files/Quantum GIS/nitelti020l.qgs
# Edit this file to customize for your map interface
MAP
NAME nitelti020l
# Map image size
SIZE 600 600
UNITS dd
EXTENT -6086744.000000 -5878356.737659 4278894.138000 7580130.593659
PROJECTION
# 'proj=longlat'
# 'ellps=WGS84'
# 'datum=WGS84'
# 'no_defs'
"init=epsg:4326"
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 192 192 192
IMAGEQUALITY 95
IMAGETYPE jpeg
OUTPUTFORMAT
NAME jpeg
DRIVER 'GD/JPEG'
MIMETYPE 'image/jpeg'
#IMAGEMODE PC256
EXTENSION 'jpeg'
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
# WMS server settings
METADATA
'wms_title' 'nitelti020l'
'wms_onlineresource' 'http://localhost/cgi-bin/mapserv?map=wms.map&'
'wms_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
END
WEB
LOG "c:\tmp\mapserv.log"
END
LAYER
NAME 'nitelti020l'
TYPE RASTER
DATA 'C:\oatdir\nitelti020l.tar\nitelti020l.tif'
METADATA
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
# 'proj=longlat'
# 'ellps=WGS84'
# 'datum=WGS84'
# 'no_defs'
"init=epsg:4326"
END
END
END
Raster date download
http://edcftp.cr.usgs.gov/pub/data/nationalatlas/nitelti020l.tar.gz
simple open layer code
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<style type="text/css">
#map {
width: 800px;
height: 475px;
border: 1px solid black;
</style>
<script src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
<script type="text/javascript">
var map, layer;
function init(){
map = new OpenLayers.Map( 'map' );
layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
"http://localhost/cgi-bin/mapserv.exe", {map: 'C:/Program Files/ms4w/Apache/htdocs/nitelti020l.map'} );
map.addLayer(layer);
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()">
<div id="map"></div>
</body>
</html>
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
