[mapserver-users] Drawing a circle on a map
Sucharita Samuel
iworktech.sucharita at gmail.com
Mon Apr 14 09:13:29 EDT 2008
Hi Stephen,
Thanks for the hint. I was able to draw the circle, but
now my problem is that I want to move the centroid of the circle to the
point I click on the map. I used the following code in the mapscript
layerObj oTempLayer = map.getLayerByName("Circle");
oTempLayer.open();
oTempLayer.status = (int)mapscript.MS_ON;
pointObj point = pixel2point(new pointObj(x, y, 0, 0));
rectObj oRect = oTempLayer.getExtent();
shapeObj oShp= oRect.toPolygon();
pointObj oPoint = oShp.getCentroid();
oPoint.setXY(point.x, point.y, 0);
oShp.draw(map, oTempLayer, oImg);
oImg = map.draw();
oTempLayer.draw(map, oImg);
Can you please help me to rectify the above code?
Thanks,
Sucharita
On Sun, Apr 13, 2008 at 10:07 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Atul Dravid wrote:
> > Try asking for Sample Code to Stephen Woodbridge...
> > On 4/12/08, *Stephen Woodbridge* <woodbri at swoodbridge.com <mailto:
> > woodbri at swoodbridge.com>> wrote:
> > Sucharita Samuel wrote:
> > Hi all,
> > I want to draw a circle of 5 km radius around the point I
> > click on the map. I am using C# mapscript. Even if you can help
> > me with the php code, it will be of great help.
> > One way to do this is to create a template layer that defines a
> > feature that is a circle with the STATUS OFF. Then in mapscript you
> > can get the layer, set the status to ON and set the value of the
> > origin of the feature and have mapserver draw it on top of your map.
> > -Steve W.
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org <mailto:
> > mapserver-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> In mapscript you can change the status and the feature points to be what
> you want. Here is an example of the LAYER and a URL to display it. I will
> leave the mapscript as you homework assignment :) Actually, I don't have a
> simple example handy, nor the time to put one together at the moment. If you
> get stuck an a specific point ask the list, there are plently of people that
> can help with mapscript.
> -Steve
> MAP
> EXTENT -180 -90 180 90
> IMAGECOLOR 255 255 0
> IMAGETYPE png
> SIZE 400 200
> UNITS DD
> LAYER
> NAME "circles"
> TYPE circle
> STATUS DEFAULT
> FEATURE
> # define circle as two points describing the opposite corners of
> # of the bounding square about the circle
> POINTS
> -10.0 -10.0
> 10.0 10.0
> END
> END
> CLASS
> STYLE
> OUTLINECOLOR 255 0 0
> END
> END
> END
> END
> http://mt2.imaptools.com/cgi-bin/mapserv-5.1-dev?mode=map&map=/u/data/maps/circles.map
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080414/07d4f349/attachment.html
