[mapserver-users] Draw Postgis sql query
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Apr 15 07:43:14 EDT 2008
Hans Castorp wrote:
> I have some sql queries over a Postgis table (points). How can I
draw the results of these queries over the map?
Have a look at for example these documents first:
http://mapserver.gis.umn.edu/docs/reference/vector_data/postgis
http://postgis.refractions.net/docs/ch04.html#id2624379
Depending on your case you can
- insert your query directly inside the DATA sentence
- create a PostGIS view with your query
- in you want to get something more dynamic, use run-time substitution
inside DATA
http://mapserver.gis.umn.edu/docs/howto/runsub gives some hints about
run-time substitution.
-Jukka Rahkonen-
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080415/daa2ac2f/attachment.html
