[mapserver-users] querying a WFS on property alias
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Apr 15 10:57:50 EDT 2008
Bart,
We have gone through the same issue when implementing the SOS and the
solution was to pre-parse the filter and replace the occurrences of the
aliased by the real attribute name.
I will move the function so that it does the same for the wfs filter
encoding. Will let you know after I do few tests.
Best Regards,
bartvde at osgis.nl wrote:
> Hi list,
> it seems that querying a WFS on a property alias does not work in MS 5.0.2.
> Is this a known issue?
> Using something like:
> "gml_OBJ_IDENT_alias" "Identifier"
> I can't query on Identifier in the PropertyName, but it works if I use the
> attribute name OBJ_IDENT as PropertyName.
> This is kind of strange, since a WFS client can't even know this property
> is actually called OBJ_IDENT in the datamodel behind the WFS.
> Best regards,
> Bart
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
