[mapserver-users] WMS cascading
Christopher Schmidt
crschmidt at metacarta.com
Thu Apr 17 09:04:22 EDT 2008
On Thu, Apr 17, 2008 at 03:00:57PM +0200, Luca Casagrande wrote:
> On Thursday 17 April 2008 01:19:29 TC Haddad wrote:
> > Luca,
> > you must specify 23033 in the MAP projection definition, and 4326 in
> > both parts of the LAYER /metadata definition. Then Mapserver will know
> > to reproject from one to the other.
> Thanks for your answer, right now I can use the layer inside Qgis.
> Now I have noticed a strange things: if I make a request with
> WIDTH:256 HEIGHT: 256, it draws a white image. With 512x52 all is fine.
> Am I missing some other settings?
If you're using the NASA JPL WMS, I believe that this is an expected
limitation of that WMS server... at least, we've had that problem in
OpenLayers.
Regards,
Christopher Schmidt
MetaCarta
