[mapserver-users] GetCapabilities for a specific layer, not the
entire mapfile?
John Maurer
maurerj at nsidc.org
Thu Apr 17 11:08:10 EDT 2008
Thanks, Guillaume! I've decided to implement a small slant on what you
suggested. I'm going to modify my CGI to look for a "layers=layer_name"
parameter as part of an otherwise normal GetCapabilities request, as in:
mapserver.pl?service=WMS&request=GetCapabilities&layers=layer_name1,layer_name2
But otherwise it will do as you suggest: strip the specified layer(s)
from the larger GetCapabilities request and pass this along to the end
user so that only these layers are presented. I wish that the WMS spec
had provided this capability to begin with! Maybe a good idea for the
next release from OGC (1.1.2?)...
Thanks again!
Cheers,
John Maurer
http://nsidc.org/data/atlas/
Guillaume Sueur wrote:
> Your very welcome !
> I can send you my own proxy function in Python if you want
> regards,
> Guillaume
> John Maurer a écrit :
>> Hi Guillaume,
>> Thank you for your suggestion. I still think it's unfortunate there
>> isn't something built into the existing OGC specifications to handle
>> this sort of thing. I'm weighing my various options still and will
>> see what's best. Your suggestion seems like the most straightforward
>> to implement so far. I appreciate you spending the time to e-mail me!
>> Cheers,
>> John Maurer
>>> Hi John,
>>> Maybe you can also filter the getCapabilities on the server side :
>>> make a wrapper which will get called by the client (for instance :
>>> www.server.net/myOwnCapabilities?layer=layer_name&map=map.map
>>> the wrapper will perform the standard getCapabilities on
>>> http://localhost/cgi-bin/mapserv and then manipulate the XML doc to
>>> erase all the layers nodes not requested by the user.
>>> If it suits your need, you can go this way.
>>> Hope that helps
>>> Guillaume
>>>> Hi mapserver-users,
>>>> What is the best way to provide a generic/flexible WMS-related URL
>>>> for a specific layer within my MapServer mapfile? I want to include
>>>> this kind of thing in our DIF & FGDC metadata so that users know
>>>> about a WMS for a given data set. If I provide a GetCapabilities
>>>> request, this advertises *all* of the layers in my mapfile, which
>>>> represent a collection of multiple data sets, most of which will be
>>>> unrelated to the data set in the metadata. On the other hand, if I
>>>> provide a GetMap request this allows me to specify the layer
>>>> intended for a particular data set, but it limits the output
>>>> possibilities to a specific srs, format, width, height, and bbox. A
>>>> GetCapabilities for a specific layer would be akin to what I need,
>>>> but I don't think that's how it works. This is my quandary and I'm
>>>> hoping somebody has a solution to this kind of thing??
>>>> Thanks!
>>>> Cheers,
>>>> John Maurer
John Maurer
Web/Database Applications Engineer
National Snow and Ice Data Center (NSIDC)
University of Colorado at Boulder
http://cires.colorado.edu/~maurerj
"Without geography, you're nowhere!"
