[mapserver-users] GetCapabilities for a specific layer, not the
entire mapfile?
Armin Burger
armin.burger at gmx.net
Thu Apr 17 13:52:40 EDT 2008
On 17/04/2008 14:20, Daniel Morissette wrote:
> Armin Burger wrote:
>> [...] Or using the main map file and deleting all layers but the
>> requested one with 'removeLayer()'. This does not work with PHP
>> Mapscript since this method does not exist there.
> The removeLayer() method does not exist in PHP MapScript, but you can
> achieve the same result by using the DELETED status on the layers to
> hide from the GetCapabilities:
> $layer->set("status", MS_DELETE);
> Daniel
This never worked for me. The only effect I noticed so far when setting
a layer's status to MS_DELETE was that it was not included in the map
when I write it out to a file with $map->save().
But these layers are still listed in the getCapabilities response, they
are still existing for the $map->getAllLayerNames() method and in the
indexes of existing layers. In Python Mapscript the removeLayer function
exists and works.
Armin
