[mapserver-users] How to tile a large TIF image?
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Fri Apr 18 05:47:40 EDT 2008
Thanks for the info.
Did it like this:
Library/Frameworks/GDAL.framework/Versions/1.5/Programs/gdal_translate
-outsize 10'' 10'' -co TILED=YES gebco/bathymetry.tif gebco/
bathymetry_tiled.tif
But get the message: "Segmentation fault"
Anything that I did wrong? Or should do differently?
Thanks for a hint,
Stef
> Hi,
> Gdal_translate program has options for you:
> c:\FWTools>gdal_translate
> Usage: gdal_translate [--help-general]
> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
> CInt16/CInt32/CFloat32/CFloat64}] [-strict]
> [-of format] [-b band] [-outsize xsize[%] ysize[%]]
> [-scale [src_min src_max [dst_min dst_max]]]
> [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
> [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
> [-gcp pixel line easting northing [elevation]]*
> [-mo "META-TAG=VALUE"]* [-quiet] [-sds]
> [-co "NAME=VALUE"]*
> src_dataset dst_dataset
> By playing with -srcwin or possibly with -outsize and -projwin you
> should be able to split your image as you wish. Read more from
> http://gdal.org/gdal_translate.html
> -Jukka Rahkonen-
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org
> ] Puolesta Stefan Schwarzer
> Lähetetty: 18. huhtikuuta 2008 12:05
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] How to tile a large TIF image?
> Hi there,
> I would like to use instead of single large tif image smaller tiles.
> Although I am well aware of mapserver's and gdal's possibilities to
> create the shapes for it, I first need to "split" the large tif into
> 20 or 50 or 100 tiles.
> Can anyone give me a hint with what kind of software this is possible?
> There is an ArcGIS script, but it doesn't work on my machine ( http://arcscripts.esri.com/details.asp?dbid=13978
> Thanks for any hints,
> Stef
> ____________________________________________________________________
> Stefan Schwarzer
> Lean Back and Relax - Enjoy some Nature Photography
> http://photoblog.la-famille-schwarzer.de
> Appetite for Global Data? UNEP GEO Data Portal:
> http://geodata.grid.unep.ch
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080418/384a6967/attachment.html
