[mapserver-users] How to tile a large TIF image?
William Kyngesburye
woklist at kyngchaos.com
Fri Apr 18 09:37:16 EDT 2008
Ah, yes, make sure you have the latest GDAL framework build. There is
an optimization bug in Xcode 3.x that causes problems with GeoTIFF
format if I forget to apply a workaround. You can check for this bug
by looking at the crashlog for gdal_translate, you should see
something in the thread about geokeys.
On Apr 18, 2008, at 8:07 AM, Paul Spencer wrote:
> Sounds like a problem with your gdal install - I'm running a mac
> also and have no problems. I recommend going back to the kyngchaos
> site and downloading the latest GDAL and installing it.
> Cheers
> Paul
> On 18-Apr-08, at 9:02 AM, Stefan Schwarzer wrote:
>> Thanks a lot for these details. That should be added to the
>> existing documents!
>> But unfortunately I still get a "Segmentation fault" message...
>> Stef
>>> Stefan,
>>> I don't think you can specify 10'', you need something in pixels.
>>> But the command is also probably not what you really need to do.
>>> More likely, you should be doing the following:
>>> gdal_translate -co "TILED=YES" gebco/bathymetry.tif gebco/
>>> bathmetry_tiled.tif
>>> This will create a single tif file that has an internal block size
>>> of 256x256 - you can think of this as having broken your tif up
>>> into 256x256 tiles but keeps them all within the same file. This
>>> is equivalent to breaking the tif up into individual files,
>>> creating a shapefile that has rectangles for each individual
>>> files' extent, and using that as a tile index in mapserver.
>>> Next, you want to do this:
>>> gdaladdo gebco/bathymetry.tif 2 4 6 8 16
>>> this will pre-compute smaller versions of the tif image called
>>> overviews at 1/2, 1/4 1/6 1/8 and 1/16 of the original size of the
>>> tif - this makes it much more efficient for gdal to return exactly
>>> what mapserver is asking for at any given scale. Depending on the
>>> range of scales that you need to display your raster image at, you
>>> can add more overview levels (or take some away).
>>> With this two commands, you can make your rasters much more
>>> efficient for mapserver and probably avoid the need to split them
>>> up into many files.
>>> It does make the file somewhat larger. If you are working with
>>> very large files ( > 4GB ) then you may run into some problems
>>> with tiff and may need to investigate another format or a
>>> compressed format like ECW or MrSID (both requiring commercial
>>> licenses I believe).
>>> There are also some built in compression schemes for tiffs in gdal
>>> which you can apply when running gdal_translate (see http://www.gdal.org/frmt_gtiff.html
>>> for creation options), for instance:
>>> gdal_translate -co "TILED=YES" -co "COMPRESS=JPEG" -co
>>> "JPEG_QUALITY=80" gebco/bathymetry.tif gebco/bathmetry_tiled.tif
>>> would compress the tif using JPEG compression (lossy) set to 80%
>>> (low compression, small loss).
>>> Cheers
>>> Paul
>>> On 18-Apr-08, at 5:47 AM, Stefan Schwarzer wrote:
>>>> Thanks for the info.
>>>> Did it like this:
>>>> Library/Frameworks/GDAL.framework/Versions/1.5/Programs/
>>>> gdal_translate -outsize 10'' 10'' -co TILED=YES gebco/
>>>> bathymetry.tif gebco/bathymetry_tiled.tif
>>>> But get the message: "Segmentation fault"
>>>> Anything that I did wrong? Or should do differently?
>>>> Thanks for a hint,
>>>> Stef
>>>>> Hi,
>>>>> Gdal_translate program has options for you:
>>>>> c:\FWTools>gdal_translate
>>>>> Usage: gdal_translate [--help-general]
>>>>> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>>>>> CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>>>>> [-of format] [-b band] [-outsize xsize[%] ysize[%]]
>>>>> [-scale [src_min src_max [dst_min dst_max]]]
>>>>> [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
>>>>> [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>>>>> [-gcp pixel line easting northing [elevation]]*
>>>>> [-mo "META-TAG=VALUE"]* [-quiet] [-sds]
>>>>> [-co "NAME=VALUE"]*
>>>>> src_dataset dst_dataset
>>>>> By playing with -srcwin or possibly with -outsize and -projwin
>>>>> you should be able to split your image as you wish. Read more
>>>>> from
>>>>> http://gdal.org/gdal_translate.html
>>>>> -Jukka Rahkonen-
>>>>> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org
>>>>> ] Puolesta Stefan Schwarzer
>>>>> Lähetetty: 18. huhtikuuta 2008 12:05
>>>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>>>> Aihe: [mapserver-users] How to tile a large TIF image?
>>>>> Hi there,
>>>>> I would like to use instead of single large tif image smaller
>>>>> tiles. Although I am well aware of mapserver's and gdal's
>>>>> possibilities to create the shapes for it, I first need to
>>>>> "split" the large tif into 20 or 50 or 100 tiles.
>>>>> Can anyone give me a hint with what kind of software this is
>>>>> possible?
>>>>> There is an ArcGIS script, but it doesn't work on my machine ( http://arcscripts.esri.com/details.asp?dbid=13978
>>>>> Thanks for any hints,
>>>>> Stef
>>>>> ____________________________________________________________________
>>>>> Stefan Schwarzer
>>>>> Lean Back and Relax - Enjoy some Nature Photography
>>>>> http://photoblog.la-famille-schwarzer.de
>>>>> Appetite for Global Data? UNEP GEO Data Portal:
>>>>> http://geodata.grid.unep.ch
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Paul Spencer
>>> Chief Technology Officer
>>> DM Solutions Group Inc
>>> http://www.dmsolutions.ca/
> Paul Spencer
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
