[mapserver-users] MapServer logs
    Daniel Morissette
    dmorissette at mapgears.com
    Fri Apr 18 06:38:47 PDT 2008
P Kishor wrote:
> I want MapServer to write every call that it makes to the database via
> OGR. So, I added the following line to my map file
>   WEB
>     LOG "/Users/punkish/Sites/sqlitegis/tmp/ms.log"
>   END
IIRC, LOG only logs some info on the mapserv request status at the end
of its execution. I don't use it much and don't know much about it.
To get debugging output, with MapServer 5.0+, set:
   CONFIG "MS_ERRORFILE" "/Users/punkish/Sites/sqlitegis/tmp/ms.log"
... and then set DEBUG level (ON, or number between 1 and 5) at the
top-level in the mapfile and in each layer for which you want debugging
output.
More details are available in RFC-28:
   http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the MapServer-users
