[mapserver-users] Displaying points & label
Michael Schulz
mschulz at webgis.de
Fri Apr 18 12:25:01 EDT 2008
in your ovf as well as in the layer definition you claim your data to
be in EPSG:27582, if it is actually in epsg:4326 then it should say so
in both places. The layer projection defines in which system your data
is in, the map projection defines in what system your image is
rendered (and your data projected to on the fly if necessary).
Cheers, Michael
2008/4/18 Clemiou <clems_mars at hotmail.com>:
> Hi!
> Still no points!
> But I found perhaps something...
> My datas are in WGS84 format and my map in Lambert II.
> So, in my mapfile, my Map object has WGS84 projection, the layer of my Map, Lambert II format and the layer of my points the WGS84 format.
> But still no points.
> I don't know why. ^^
> Thanks for your help.
> Clement
> _________________________________________________________________
> Découvrez les profils Messenger de vos amis !
> http://home.services.spaces.live.com/_______________________________________________
> mapserver-users at lists.osgeo.org
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
