[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Dave Fuhry
dfuhry at gmail.com
Sun Apr 20 15:22:27 EDT 2008
Carlos,
Please retry with v6 of the patch from
http://trac.osgeo.org/mapserver/ticket/2497 and see if problems
remain. It should make some of the statements shown in your log below
impossible (namely, the lower-case "rollback" and "begin", which were
removed).
In my testing with cgi, php/mapscript, and python/mapscript, I
can't find any problems. See a couple of attached testing scripts for
examples of what I tried.
Thanks,
Dave
On Thu, Mar 27, 2008 at 5:16 PM, Carlos_Molina <dr.chamberlain at gmail.com> wrote:
> Dave Fuhry wrote:
> > Ivan,
> > p.mapper seems to use the typical php
> > {map,layer}Obj_queryBy{Point,Rect,etc.} functions. These calls end up
> > calling the same msPOSTGIS* functions as everything else.
> > I can't seem to reproduce your problem with a simple testcase
> > (basically, the attached files). It might help if you can set
> > log_min_duration_statement = 0 in your postgresql.conf, reproduce the
> > problem, and send the output from your postgresql log file. It will
> > show all commands issued to the database, including the BEGIN, and the
> > DECLARE CURSOR ..., and FETCH for every layer.
> > I can setup p.mapper if that's necessary to reproduce the problem.
> > (By the way, I assume you're not using an ancient version of
> > postgis, in the 0.5 - 0.6 era. There is an alternate codepath for
> > that, which I have not tested.)
> > Thanks,
> > Dave
> Hello Dave,
> I've tried first and second version of your patch and both resolved my first
> issue of many many BEGIN statements being issued by cursors so my
> application went back to running smoothly. The sad part is that another
> issued arised from this patch and It's when using python mapscript and the
> drawQuery call.
> If i just render my .map file with draw() I get no trouble, but if I open my
> map file, get a single layer from it, query the layer, open the layer to
> retrieve results and call drawQuery() afterwards to render everything like I
> used to do before the patch, I get the following error(I resumed the sql
> statements):
> BEGIN
> DECLARE mycursor BINARY CURSOR FOR SELECT... // queryByPoint
> FETCH ALL in mycursor
> CLOSE mycursor
> SELECT * FROM... "same as above" WHILE false LIMIT 0 // Dont know why this
> is issued, might be openLayer or just to get the field names of the table
> WARNING: there is already a transaction in progress
> BEGIN
> DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(0)
> FETCH ALL in mycursor2
> CLOSE mycursor2
> ROLLBACK
> BEGIN
> DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(1)
> CLOSE mycursor2
> ROLLBACK
> ERROR: DECLARE CURSOR may only be used in transaction blocks
> WARNING: there is no transaction in progress
> statement: rollback
> statement: begin
> ERROR: cursor "mycursor" does not exist
> ABORT
> Regards
> Carlos Molina
> View this message in context: http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-tp15786741p16333076.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080420/02c860ba/drawquery.py
Type: application/x-httpd-php
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080420/02c860ba/ms_test.bin
