[mapserver-users] MapServier and OpenLayers - with PHP?
Christopher Schmidt
crschmidt at metacarta.com
Fri Apr 18 15:57:56 EDT 2008
On Fri, Apr 18, 2008 at 02:45:12PM -0500, Richard Marsden wrote:
> This looks simple enough, except for the MapScript URL! Where does it
> get the map file from?
1. '/wms/vmap0' doesn't use Mapscript, it uses MapServer as a CGI.
2. That path is a minimal CGI: it looks like:
#!/bin/sh
export MS_MAPFILE=/www/labs/map/vmap0.map
exec /usr/lib/cgi-bin/mapserv
There's nothing hidden here, it just makes the URL prettier. You can
equally do:
http://localhost/cgi-bin/mapserv?map=/www/labs/map/vmap0.map
instead.
> How would I get this to work with PHP, considering I can't get CGI to work?
I would suggest that getting CGI to work is likely to be a better path
than trying to write a WMS request handler in PHP. Perhaps you should
expand on why it doesn't work: you mentioned not being able to restart
Apache: is that something that a web host could help you resolve? Does
your web host allow you to run CGI executables?
Regards,
Christopher Schmidt
MetaCarta
