[mapserver-users] grayscale shaded relief in mapserver
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Mon Apr 21 12:34:20 EDT 2008
the main projection is the same. Extents are ok, the tif being much
wider than the rest of the dataset. I'm explicitly calling it, and it
returns a white image. shp2img on this specific layer does the same.
The raster values range from 0 to 255, but on my particuliar mapping
zone, the are few differences between pixel values. I'm using GIF PC256
for output.
Fawcett, David a écrit :
> Have you ruled out a problem with projection or extent?
> I was hoping to see the top of the map file too, to see what the output projection, extent, and units lines looked like.
> Also, are you calling the layer name explicitly in the cgi request? If not, try setting the layer status to DEFAULT for testing purposes.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Sueur
> Sent: Monday, April 21, 2008 11:17 AM
> To: Fawcett, David; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] grayscale shaded relief in mapserver
> the TIF goes with a .TAB and its georeferencing informations. It looks
> ok with Qgis.
> The mapfile is straight-forward :
> LAYER
> DATA "uploaded/AUbwV8_32.TIF"
> NAME "shaded"
> PROCESSING "COLOR_MATCH_THRESHOLD=3"
> PROJECTION
> "init=epsg:27563"
> END
> STATUS ON
> TYPE RASTER
> UNITS METERS
> END
> Thanks for your interest,
> Guillaume
>> Have you stripped out all of the projection, etc. and just tried to
>> output the image?
>> What does your map file look like?
>> David.
>> Guillaume Sueur
>> Sent: Monday, April 21, 2008 3:48 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] grayscale shaded relief in mapserver
>> Hi list,
>> I've got a grayscale TIF showing shaded relief which I can't manage to
>> display properly with mapserver. The image is just white. gdalinfo gives
>> : Band 1 Block=4367x1 Type=Byte, ColorInterp=Gray I assume the georef is
>> ok. I tried few things like resampling it to 32 colors, or "PROCESSING
>> "COLOR_MATCH_THRESHOLD=3" as I've found in mails archives, but without
>> any luck.
>> Any clue ?
>> Thanks
> mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
