[mapserver-users] grayscale shaded relief in mapserver
Jeff McKenna
jeffmckenna at gmail.com
Mon Apr 21 12:41:00 EDT 2008
my thoughts:
- make a tiny version of your mapfile with only that one problem layer
- remove all projection objects
- post this small mapfile and your shp2img output (with the -map_debug
switch) to this email list
-jeff
On 21-Apr-08, at 12:34 PM, Guillaume Sueur wrote:
> the main projection is the same. Extents are ok, the tif being much
> wider than the rest of the dataset. I'm explicitly calling it, and
> it returns a white image. shp2img on this specific layer does the
> same.
> The raster values range from 0 to 255, but on my particuliar mapping
> zone, the are few differences between pixel values. I'm using GIF
> PC256 for output.
> Fawcett, David a écrit :
>> Have you ruled out a problem with projection or extent? I was
>> hoping to see the top of the map file too, to see what the output
>> projection, extent, and units lines looked like. Also, are you
>> calling the layer name explicitly in the cgi request? If not, try
>> setting the layer status to DEFAULT for testing purposes.
>> David.
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org
>> ] On Behalf Of Guillaume Sueur
>> Sent: Monday, April 21, 2008 11:17 AM
>> To: Fawcett, David; mapserver-users at lists.osgeo.org
>> Subject: Re: [mapserver-users] grayscale shaded relief in mapserver
>> the TIF goes with a .TAB and its georeferencing informations. It
>> looks ok with Qgis.
>> The mapfile is straight-forward :
>> LAYER
>> DATA "uploaded/AUbwV8_32.TIF"
>> NAME "shaded"
>> PROCESSING "COLOR_MATCH_THRESHOLD=3"
>> PROJECTION
>> "init=epsg:27563"
>> END
>> STATUS ON
>> TYPE RASTER
>> UNITS METERS
>> END
>> Thanks for your interest,
>> Guillaume
>>> Have you stripped out all of the projection, etc. and just tried
>>> to output the image?
>>> What does your map file look like?
>>> David.
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>>> Guillaume Sueur
>>> Sent: Monday, April 21, 2008 3:48 AM
>>> To: mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] grayscale shaded relief in mapserver
>>> Hi list,
>>> I've got a grayscale TIF showing shaded relief which I can't
>>> manage to
>>> display properly with mapserver. The image is just white. gdalinfo
>>> gives
>>> : Band 1 Block=4367x1 Type=Byte, ColorInterp=Gray I assume the
>>> georef is
>>> ok. I tried few things like resampling it to 32 colors, or
>>> "PROCESSING "COLOR_MATCH_THRESHOLD=3" as I've found in mails
>>> archives, but without any luck.
>>> Any clue ?
>>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
