[mapserver-users] grayscale shaded relief in mapserver
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Mon Apr 21 15:50:38 EDT 2008
I've done a tileindex, and when I set the layer to polygon and data to
my tileindex shape, it displays well. So I think it's not a
georeferencing problem.
Does anything could render as null (transparent or white, depending of
outputformat) some raster layer without any error ?
Thanks
Guillaume
Jeff McKenna a écrit :
> my thoughts:
> - make a tiny version of your mapfile with only that one problem layer
> - remove all projection objects
> - post this small mapfile and your shp2img output (with the -map_debug
> switch) to this email list
> -jeff
> On 21-Apr-08, at 12:34 PM, Guillaume Sueur wrote:
>> the main projection is the same. Extents are ok, the tif being much
>> wider than the rest of the dataset. I'm explicitly calling it, and it
>> returns a white image. shp2img on this specific layer does the same.
>> The raster values range from 0 to 255, but on my particuliar mapping
>> zone, the are few differences between pixel values. I'm using GIF
>> PC256 for output.
>> Fawcett, David a écrit :
>>> Have you ruled out a problem with projection or extent? I was hoping
>>> to see the top of the map file too, to see what the output
>>> projection, extent, and units lines looked like. Also, are you
>>> calling the layer name explicitly in the cgi request? If not, try
>>> setting the layer status to DEFAULT for testing purposes.
>>> David.
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>>> Guillaume Sueur
>>> Sent: Monday, April 21, 2008 11:17 AM
>>> To: Fawcett, David; mapserver-users at lists.osgeo.org
>>> Subject: Re: [mapserver-users] grayscale shaded relief in mapserver
>>> the TIF goes with a .TAB and its georeferencing informations. It
>>> looks ok with Qgis.
>>> The mapfile is straight-forward :
>>> LAYER
>>> DATA "uploaded/AUbwV8_32.TIF"
>>> NAME "shaded"
>>> PROCESSING "COLOR_MATCH_THRESHOLD=3"
>>> PROJECTION
>>> "init=epsg:27563"
>>> END
>>> STATUS ON
>>> TYPE RASTER
>>> UNITS METERS
>>> END
>>> Thanks for your interest,
>>> Guillaume
>>>> Have you stripped out all of the projection, etc. and just tried to
>>>> output the image?
>>>> What does your map file look like?
>>>> David.
>>>> Guillaume Sueur
>>>> Sent: Monday, April 21, 2008 3:48 AM
>>>> To: mapserver-users at lists.osgeo.org
>>>> Subject: [mapserver-users] grayscale shaded relief in mapserver
>>>> Hi list,
>>>> I've got a grayscale TIF showing shaded relief which I can't manage to
>>>> display properly with mapserver. The image is just white. gdalinfo
>>>> gives
>>>> : Band 1 Block=4367x1 Type=Byte, ColorInterp=Gray I assume the
>>>> georef is
>>>> ok. I tried few things like resampling it to 32 colors, or
>>>> "PROCESSING "COLOR_MATCH_THRESHOLD=3" as I've found in mails
>>>> archives, but without any luck.
>>>> Any clue ?
>>>> Thanks
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
