[MAPSERVER-USERS] Connecting to PostGIS only one time for all
the layers
rich.fromm
nospam420 at yahoo.com
Mon Apr 21 19:31:07 EDT 2008
Emilio Ponce wrote:
> I want to connect only one time to a PostGIS database, in order to
> improve the efficiency of my mapfile. Now I'm connecting in every
> layer with this lines:
> CONNECTIONTYPE postgis
> CONNECTION "host= ... "
> DATA "the_geom from comarcas
> Is there a way to do this only one time in all the mapfile using more
> than one layer?
In each LAYER, add:
PROCESSING "CLOSE_CONNECTION=DEFER"
This tells mapserver not to close the connection. So you still need to
specify the connection multiply, but that's not that big of a deal, and you
will get the performance gain. This is documented here:
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer
But there are some caveats, and you might find yourself needing to apply a
local patch. For more details, see:
http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-to15786741.html
http://trac.osgeo.org/mapserver/ticket/2497
- Rich
View this message in context: http://www.nabble.com/Connecting-to-PostGIS-only-one-time-for-all-the-layers-tp16816322p16817687.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
