[mapserver-users] postgis wms bounding box
Frank Broniewski
liste at geo-dienstleistung.de
Tue Apr 22 05:26:42 EDT 2008
Hello List,
I am setting up a wms server which retrieves its data from a postgis database
and I am having trouble displaying the layer in QGIS or OpenJump correctly.
QGIS doesn't show anything at all, while openjump requires zooming in to see
the data. A getmap request (without bbox-parameter) in the browser does give
me a "correct" view of the data. I am using on Ubuntu 7.10
MapServer version 4.10.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
Having a look at the getcapabilites document, there seems to be a problem with
the calculation of the layer extents: here's the global extent from the
getcapabilities response:
<LatLonBoundingBox minx="5.73166" miny="49.446" maxx="6.53226"
maxy="50.1818" />
<BoundingBox SRS="EPSG:2169" minx="48928" miny="57005" maxx="106114"
maxy="138765" />
And here's the bbox from the actual postgis layer:
<LatLonBoundingBox minx="-179.798" miny="-2.19659e+13" maxx="177.392"
maxy="2.63905e+18" />
<BoundingBox SRS="EPSG:2169" minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07"
maxy="2.5e+07" />
As you can see, the bounding box of the layer is completely wrong. It should
nearly be the same as the global extent. The data definition in the mapfile
is:
Data "centroid from public.locations using unique id"
Any suggestions? Should I return a bbox in the data query for the postgis
layer to prevent the wrong bbox of the layer? And if yes, how do I do this?
Greetings from Luxembourg
Frank
