[mapserver-users] postgis wms bounding box
Michael Schulz
mschulz at webgis.de
Tue Apr 22 06:29:46 EDT 2008
Hi Frank,
that is a known problem with postgis layers. If i recall it correctly
it is basically due to the fact that it is timely expensive to
calculate the extent of a postgis layer (it'd need to be done for each
getCap request). You can come around this by specifying the wms_extent
metadata parameter for that layer manually.
Cheers, Michael
2008/4/22 Frank Broniewski <liste at geo-dienstleistung.de>:
> Hello List,
> I am setting up a wms server which retrieves its data from a postgis database
> and I am having trouble displaying the layer in QGIS or OpenJump correctly.
> QGIS doesn't show anything at all, while openjump requires zooming in to see
> the data. A getmap request (without bbox-parameter) in the browser does give
> me a "correct" view of the data. I am using on Ubuntu 7.10
> MapServer version 4.10.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> Having a look at the getcapabilites document, there seems to be a problem with
> the calculation of the layer extents: here's the global extent from the
> getcapabilities response:
> <LatLonBoundingBox minx="5.73166" miny="49.446" maxx="6.53226"
> maxy="50.1818" />
> <BoundingBox SRS="EPSG:2169" minx="48928" miny="57005" maxx="106114"
> maxy="138765" />
> And here's the bbox from the actual postgis layer:
> <LatLonBoundingBox minx="-179.798" miny="-2.19659e+13" maxx="177.392"
> maxy="2.63905e+18" />
> <BoundingBox SRS="EPSG:2169" minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07"
> maxy="2.5e+07" />
> As you can see, the bounding box of the layer is completely wrong. It should
> nearly be the same as the global extent. The data definition in the mapfile
> is:
> Data "centroid from public.locations using unique id"
> Any suggestions? Should I return a bbox in the data query for the postgis
> layer to prevent the wrong bbox of the layer? And if yes, how do I do this?
> Greetings from Luxembourg
> Frank
> mapserver-users at lists.osgeo.org
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
