[mapserver-users] AJAX - GetFeatureInfo - Accent problem
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 24 09:04:01 EDT 2008
OOpps... sorry for responding to myself, but I just realized that you
are using an HTML template for your GetFeatureInfo query and not GML. In
this case the ows_encoding setting will have no effect. However you
could and should set the encoding yourself in the header of the query
template.
Daniel
Daniel Morissette wrote:
> Martin,
> Did you try setting "ows_encoding" "ISO-8859-1" in the map-level
> metadata? With this metadata directive, MapServer will include an
> encoding value in the <?xml ...> header of the GetFeatureInfo response,
> and hopefully that will be caught by the XMLHttpRequest.
> Daniel
> Martin Ouellet wrote:
>> Hi,
>> I have a GetFeatureinfo request that work pretty well (the accent
>> character is OK) )when I call it directly in IE or FF:
>> http://MDRIM00-000251/mapserver5/siglight.exe&service=WMS&version=1.1.1&request=getfeatureinfo&info_format=text/html&srs=EPSG:4326
>> <http://MDRIM00-000251/mapserver5/siglight.exe&service=WMS&version=1.1.1&request=getfeatureinfo&info_format=text/html&srs=EPSG:4326>
>> &bbox=-71.332572,46.716784,-71.247428,46.783216&width=992&height=774&layers=hauteur_libre&query_layers=hauteur_libre&feature_count=10&x=423&y=313&format=gif&styles=
>> ex: Municipalité: Québec
>> The template behind this layer is a very simple HTML file (saved in
>> DOS/ISO-8859-1 encoding):
>> <table border="0" cellpadding="0" width="100%" class="gfi-label">
>> <tr valign="top">
>> <td align="right">Municipalité:</td>
>> <td class="gfi-value">[Municipali]</td>
>> </tr>
>> </table>
>> But when I send the same URL request in AJAX, the accent character are
>> not displayed correctly (in the responseText of the XMLHttpRequest
>> object).
>> ex: Municipalit? Qu?c
>> For firefox, I have fix the problem by adding this line:
>> xmlHttp.overrideMimeType('text/html; charset=ISO-8859-1');
>> But this method is not supported by IE. I presume it's not a
>> Mapserver issue but if someone has any clue???
>> Thank you in advance.
>> MartinO
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
http://www.mapgears.com/
