[mapserver-users] AJAX - GetFeatureInfo - Accent problem
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 24 08:56:34 EDT 2008
Martin,
Did you try setting "ows_encoding" "ISO-8859-1" in the map-level
metadata? With this metadata directive, MapServer will include an
encoding value in the <?xml ...> header of the GetFeatureInfo response,
and hopefully that will be caught by the XMLHttpRequest.
Daniel
Martin Ouellet wrote:
> Hi,
> I have a GetFeatureinfo request that work pretty well (the accent
> character is OK) )when I call it directly in IE or FF:
> http://MDRIM00-000251/mapserver5/siglight.exe&service=WMS&version=1.1.1&request=getfeatureinfo&info_format=text/html&srs=EPSG:4326
> <http://MDRIM00-000251/mapserver5/siglight.exe&service=WMS&version=1.1.1&request=getfeatureinfo&info_format=text/html&srs=EPSG:4326>
> &bbox=-71.332572,46.716784,-71.247428,46.783216&width=992&height=774&layers=hauteur_libre&query_layers=hauteur_libre&feature_count=10&x=423&y=313&format=gif&styles=
> ex: Municipalité: Québec
> The template behind this layer is a very simple HTML file (saved in
> DOS/ISO-8859-1 encoding):
> <table border="0" cellpadding="0" width="100%" class="gfi-label">
> <tr valign="top">
> <td align="right">Municipalité:</td>
> <td class="gfi-value">[Municipali]</td>
> </tr>
> </table>
> But when I send the same URL request in AJAX, the accent character are
> not displayed correctly (in the responseText of the XMLHttpRequest object).
> ex: Municipalit? Qu?c
> For firefox, I have fix the problem by adding this line:
> xmlHttp.overrideMimeType('text/html; charset=ISO-8859-1');
> But this method is not supported by IE. I presume it's not a Mapserver
> issue but if someone has any clue???
> Thank you in advance.
> MartinO
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
