[mapserver-users] AGG - FORMATOPTION PALETTE
Léveillé, James
James.Leveille at mtq.gouv.qc.ca
Thu Apr 24 09:29:57 EDT 2008
I'm trying to use my own palette for AGG as described here by Thomas :
http://www.nabble.com/forced-palette-and-quantization-for-RGBA-images-td1464
5869.html
As explained in the article, I'm using a typical PNG 24 bits image (produced
in RGBA mode - 4 bands).
But from this image, I'm not able to produce a 8 bits PNG image with the
ALPHA, only in RGB with 3 channels - see the GDALINFO below.
I need this 8 bits image to generate my palette.
Driver: PNG/Portable Network Graphics
Size is 1203, 813
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 813.0)
Upper Right ( 1203.0, 0.0)
Lower Right ( 1203.0, 813.0)
Center ( 601.5, 406.5)
Band 1 Block=1203x1 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 17,12,12,255
1: 27,101,44,255
2: 0,132,0,255
3: 19,130,16,255
How can I generate a 8 bits RGBA image from the original 24 bits image ?
Regards.
JAMES
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080424/a61f0e4a/attachment.html
