[mapserver-users] Large scale PDF output on Windows
Carl Anderson
carl.anderson at vadose.org
Thu Apr 24 23:18:14 EDT 2008
Maning,
We have built a custom system that builds large format maps using UMN
Mapserver output as SVG and some extra static template stuff
An example can be seen at
http://wms.co.fulton.ga.us/apps/custommaps/select_type.php?view_layers=-layer=streets-layer=daccess-layer=hillshade-layer=buildings-layer=current_parcels-layer=subdiv-layer=city_limits-layer=ponds-layer=streams&objectid=xxxxxx&xmin=2171270.340465&ymin=1329959.560581&xmax=2191269.791276&ymax=1343188.595973
A different map can be pulled from
http://wfs.co.fulton.ga.us/apps/tilemaps/get_tile.php?intile=136101
We are converting the system to be entirely mapserver SVG output based,
with the conversion to PDF as the last step. the maps are vector maps
and not raster maps so they are less limited by map size.
If you want the PHP code that assembles these maps let me know.
C.
Carl Anderson
IS/GIS Manager Fulton County GA, USA
maning sambale wrote:
> hi,
> Are there any example of WMS with pdf output available over the web?
> I tried the mumbai map but can't get a pdf output.
> cheers,
> maning
> On Thu, Apr 24, 2008 at 9:01 PM, Flavio Hendry <flavio at tydac.ch> wrote:
>> Hi Bart
>> Discussed the issue a while ago with Frank Warmerdam. He had less
>> problems on a LINUX System running on a 64bit machine (he supposes it
>> could go as high as 25'000 pixels). On Windows 32 it bangs at around
>> 10'000 to 14'000 pixels depending on content. Did not try on Windows 64.
>> Mit freundlichem Gruss / Best Regards
>> Flavio Hendry
>> TYDAC Web-Site: http://www.tydac.ch
>> TYDAC MapServer: http://www.mapserver.ch
>> TYDAC SwissMaps: http://www.mapplus.ch
>> ############ Mit freundlichen Gruessen / Kind Regards
>> ############ mailto:flavio at tydac.ch
>> ############ TYDAC AG - http://www.tydac.ch
>> #### #### Geographic Information Solutions
>> #### #### Luternauweg 12 -- CH-3006 Bern
>> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
>> Location: http://www.mapplus.ch/adr/bern/luternauweg/12
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
