[mapserver-users] Large scale PDF output on Windows
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 25 01:07:12 EDT 2008
Carl,
I would like to get a copy of this as well. I think this would make a
great contribution to the mapserver wiki or a mapserver HowTo if you are
willing to contribute it.
Thanks,
-Steve W
Carl Anderson wrote:
> Maning,
> We have built a custom system that builds large format maps using UMN
> Mapserver output as SVG and some extra static template stuff
> An example can be seen at
> http://wms.co.fulton.ga.us/apps/custommaps/select_type.php?view_layers=-layer=streets-layer=daccess-layer=hillshade-layer=buildings-layer=current_parcels-layer=subdiv-layer=city_limits-layer=ponds-layer=streams&objectid=xxxxxx&xmin=2171270.340465&ymin=1329959.560581&xmax=2191269.791276&ymax=1343188.595973
> A different map can be pulled from
> http://wfs.co.fulton.ga.us/apps/tilemaps/get_tile.php?intile=136101
> We are converting the system to be entirely mapserver SVG output based,
> with the conversion to PDF as the last step. the maps are vector maps
> and not raster maps so they are less limited by map size.
> If you want the PHP code that assembles these maps let me know.
> C.
> Carl Anderson
> IS/GIS Manager Fulton County GA, USA
> maning sambale wrote:
>> hi,
>> Are there any example of WMS with pdf output available over the web?
>> I tried the mumbai map but can't get a pdf output.
>> cheers,
>> maning
>> On Thu, Apr 24, 2008 at 9:01 PM, Flavio Hendry <flavio at tydac.ch> wrote:
>>> Hi Bart
>>> Discussed the issue a while ago with Frank Warmerdam. He had less
>>> problems on a LINUX System running on a 64bit machine (he supposes it
>>> could go as high as 25'000 pixels). On Windows 32 it bangs at around
>>> 10'000 to 14'000 pixels depending on content. Did not try on Windows
>>> 64.
>>> Mit freundlichem Gruss / Best Regards
>>> Flavio Hendry
>>> TYDAC Web-Site: http://www.tydac.ch
>>> TYDAC MapServer: http://www.mapserver.ch
>>> TYDAC SwissMaps: http://www.mapplus.ch
>>> ############ Mit freundlichen Gruessen / Kind Regards
>>> ############ mailto:flavio at tydac.ch
>>> ############ TYDAC AG - http://www.tydac.ch
>>> #### #### Geographic Information Solutions
>>> #### #### Luternauweg 12 -- CH-3006 Bern
>>> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
>>> Location: http://www.mapplus.ch/adr/bern/luternauweg/12
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
