[mapserver-users] OpenLayers & Projection
Clemiou
clems_mars at hotmail.com
Tue Apr 29 15:46:50 EDT 2008
Hi!
I provide you my OpenLayers code.
function init()
OpenLayers.DOTS_PER_INCH = 72;
// Tableau des options pour la carte. //
// La plus importante est scales qui permet de definir les différents zooms //
// qui seront disponibles pour l'utilisateur. //
var options =
scales: [3500000, 3000000,2500000,2000000,1500000,1000000,350000,250000],
maxScale: 250000,
minScale: 3500000,
controls: [new OpenLayers.Control.MouseDefaults()]
// Création de l'objet map. //
map = new OpenLayers.Map( 'map',options);
// On ajoute les couches après les avoir créées. //
layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
"http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/html/ms/map_files/france.map", {layers: ['FRANCE','CORSE']},
{gutter: 0 });
map.addLayer(layer);
// Ajout de la barre de zoom et des coordonnées de la position actuelle. //
map.addControl( new OpenLayers.Control.PanZoomBar() );
// Ajout de la gestion du click. //
var click = new OpenLayers.Control.Click();
map.addControl(click);
click.activate();
// Et on définit le centre de notre carte, afin qu'elle sot bien positionnée. //
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
And my mapfile has the good projections block, one for the map and one for each layer. Consequently, it works with mapserver & without OL.
Regards.
Clement
> Date: Tue, 29 Apr 2008 15:43:32 -0400
> From: jlacroix at mapgears.com
> To: clems_mars at hotmail.com
> CC: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] OpenLayers & Projection
> Hi,
> You can take a look at how projection are set in OpenLayers:
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
> Or at the Source of the OpenLayers projection example:
> http://www.openlayers.org/dev/examples/projected-map.html
> You will also need to define the PROJECTION block at the layer level and
> at the map level in your mapfile.
> Julien
> PS: Please provide revelent mapfile part and revelent code when asking a
> question it will help us figuring out what may be your problem.
> Clemiou wrote:
> > Hi all!
> > I come back here because I always have the same problem.
> > So, I have a .ewc file which represent the France. This file is in Lambert II (French position, centered on France).
> > Currently, I display this map with WGS84 projection but naturally, my map is distorded because this projection is centered on the equator.
> > So, if I try to displaying my map with the Lambert II projection, I obtain the following figure:
> > http://www.forumsig.org/attachment.php?attachmentid=2286&stc=1&d=1208951661 <http://www.forumsig.org/attachment.php?attachmentid=2286&stc=1&d=1208951661>
> > As you can see, there is a malfunction=> the repetition of a part of each tile.
> > I tried to add projection and units options to my map but nothing change. I think that is a OpenLayers probleme because my map is correctly display with Mapserver and without OL.
> > Perhaps someone here should help me.
> > Thanks for your futur help and once more, excuse me for my English.
> > Have a nice day
> > Clement
> > Plus de 15 millions de français utilisent Windows Live Messenger !
> > Téléchargez Messenger, c'est gratuit !
> > <http://www.windowslive.fr/messenger/>
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Julien-Samuel Lacroix
> Mapgears
> http://www.mapgears.com/
_________________________________________________________________
Découvrez les profils Messenger de vos amis !
http://home.services.spaces.live.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080429/199553d6/attachment-0001.html
