[mapserver-users] MapServer Animation Examples of Pipeline Flow?
Bill Thoen
bthoen at gisnet.com
Sat Aug 2 14:06:37 EDT 2008
I've got a little project that requires an "eye-catching" display of
flow through a network of gas pipelines. I'm using MapServer 5.0.3 (with
AGG) on Fedora Core 9 and I want to stick with open source technology if
possible.
Are there any examples out there of MapServer showing animation effects
along a linear feature (i.e. road, river, pipeline, information
flowlines, etc.) that I could look at to get some ideas?
The first thought I had was to move colored dots along a pipeline in the
direction of flow and use a timer to pace the animation. Each dot would
represent the day's load from a source and they would move based on pipe
diameter, pressure and other parameters that affect flow. This works,
but the down side is that eventually you have a lot of objects to juggle
and performance goes to heck.
Then I thought of using a series of textures for each pipeline segment
and swapping them iteratively to simulate an animating.
What won't work is rendering the entire map image each time; that would
go from eye-catching to mind-numbing pretty fast. So is there a way with
MapServer to display a map base, but allow for objects to be "floated"
on top in such away that I don't have to re-render the the entire map
each time? (like an AJAX tool for mapserver?)
If anyone has any ideas or knows of examples they could point me to, I'd
appreciate it.
- Bill Thoen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080802/8ac0474e/attachment.html
