Fw: [mapserver-users] MapServer Animation Examples of Pipeline Flow?
J.J. Schlafley
jjschlafley at yahoo.com
Sat Aug 2 14:29:33 EDT 2008
Microsoft's Virtual Earth and Google Maps uses a vector layer (VML or SVG) on top of their raster layer (basemap) to show driving directions.
----- Original Message ----
To: mapserver-users at lists.osgeo.org
Sent: Saturday, August 2, 2008 2:06:37 PM
Subject: [mapserver-users] MapServer Animation Examples of Pipeline Flow?
I've got a little project that requires an "eye-catching" display of flow through a network of gas pipelines. I'm using MapServer 5.0.3 (with AGG) on Fedora Core 9 and I want to stick with open source technology if possible.
Are there any examples out there of MapServer showing animation effects along a linear feature (i.e. road, river, pipeline, information flowlines, etc.) that I could look at to get some ideas?
The first thought I had was to move colored dots along a pipeline in the direction of flow and use a timer to pace the animation. Each dot would represent the day's load from a source and they would move based on pipe diameter, pressure and other parameters that affect flow. This works, but the down side is that eventually you have a lot of objects to juggle and performance goes to heck.
Then I thought of using a series of textures for each pipeline segment and swapping them iteratively to simulate an animating.
What won't work is rendering the entire map image each time; that would go from eye-catching to mind-numbing pretty fast. So is there a way with MapServer to display a map base, but allow for objects to be "floated" on top in such away that I don't have to re-render the the entire map each time? (like an AJAX tool for mapserver?)
If anyone has any ideas or knows of examples they could point me to, I'd appreciate it.
- Bill Thoen
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080802/deb3c0d7/attachment.html
