[mapserver-users] Problems with TrueType Symbol and Linestyle after
Switching to AGG
Bill Thoen
bthoen at gisnet.com
Sat Aug 2 17:02:46 EDT 2008
I just built MapServer 5.0.3 with AGG 2.5 support on my FC9 box and
while my maps now look LOTS nicer, I noticed that the TrueType symbols
that I use for Fire stations now appear as an open box, and my railroad
lines have lost their crossties. When I use the GD driver in the map
file OUTPUTFORMAT section, these items still appear correctly. But when
I use the AGG driver they don't. Can anyone tell me what's wrong? (I've
been searching vain for some comprehensive MapServer-AGG documentation
but the only two docs I've found (the Migration_Guide and
AGG_Rendering_Specifics) didn't help me.
Here's how I've defined the fire stations in my symbol file:
SYMBOL
NAME 'station'
TYPE TRUETYPE
FONT 'ers_ops_1'
CHARACTER 'Y'
ANTIALIAS TRUE
FILLED TRUE
END
And here's how I set up that layer in my map file:
LAYER
NAME stations
TYPE POINT
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "FireStations.TAB"
LABELITEM "Name"
CLASS
NAME "Fire Stations"
EXPRESSION ([id] ne 6)
SYMBOL "station"
SIZE 32
COLOR 255 0 0
OUTLINECOLOR 255 255 255
LABEL
COLOR 0 0 0
POSITION LC
SIZE medium
END
TEMPLATE "/var/www/html/blt/longmont/stations.html"
END
TOLERANCE 5
HEADER "/var/www/html/blt/longmont/stations_header.html"
FOOTER "/var/www/html/blt/longmont/footer.html"
PROJECTION
"init=epsg:4326"
END
END
The rail lines ares set up like so in the symbol file:
SYMBOL
NAME 'track'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
SYMBOL
NAME "tie"
TYPE cartoline
LINECAP butt
LINEJOIN miter
LINEJOINMAXSIZE 3
STYLE
1 10 1 10
END
END
and in the map file:
LAYER
NAME railroads
GROUP transportation
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "railroads.TAB"
LABELITEM "Name"
CLASS
NAME "Railroads"
STYLE
SYMBOL 'track'
SIZE 1
COLOR 128 128 128
END
STYLE
SYMBOL "tie"
SIZE 5
COLOR 128 128 128
END
END
PROJECTION
"init=epsg:4326"
END
END
