[MAPSERVER-USERS] How to map attribute data (non-geom) from
Oracle(not Spatial)?
Bill Wordsworth
bill.wordsworth at gmail.com
Tue Aug 5 16:01:55 EDT 2008
Tim,
I didn't know you could do "geom from..." without Oracle Spatial, so
this is great!
This is my current compilation:
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
DEBUG=MSDEBUG
I don't see any Oracle support. Could you shed some light on how to
enable that? And how do you insert geom into Oracle Locator without
Oracle Spatial- what tools?
So as I understand, Oracle Spatial allows geoprocessing type queries
(buffer, nearest, shortest) while Oracle Locator doesn't allow any
thing that but does display geom (point, line, polygon, (raster)).
Correct?? I just want to take a shapefile, insert it and then display
its filtered set.
Cheers, Bill
On Tue, Aug 5, 2008 at 10:38 AM, Nolte, Tim
<Tim.Nolte at ipcswirelessinc.com> wrote:
> Bill,
> Here is a layer definition I am using for Oracle Spatial(Locator) data.
> LAYER
> GROUP "Cell Sites"
> NAME "On-Air"
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE oraclespatial
> CONNECTION "username/password at sid"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "geom FROM (SELECT st.bts_nbr, sgt.geom FROM site_tab st,
> site_geom_tab sgt WHERE st.site_id = sgt.site_id AND st.site_status_id
> IN (4,7)) USING SRID 8307"
> LABELITEM "bts_nbr"
> METADATA
> "static_legend" "1"
> END
> DUMP true
> CLASS
> NAME "On-Air Large Scale"
> MINSCALE 0
> MAXSCALE 1200000
> STYLE
> SYMBOL "circle"
> COLOR 22 129 17
> OUTLINECOLOR 255 255 255
> SIZE 12
> END
> LABEL
> TYPE TRUETYPE
> FONT "sans"
> SIZE 7
> POSITION CR
> OFFSET 0 2
> ANGLE AUTO
> BUFFER 3
> MINDISTANCE 30
> MINFEATURESIZE 10
> COLOR 0 0 0
> OUTLINECOLOR 245 245 231
> SHADOWSIZE 3 3
> BACKGROUNDSHADOWSIZE 1 -1
> END
> END
> CLASS
> NAME "On-Air Small Scale"
> MINSCALE 1200000
> MAXSCALE 6000000
> STYLE
> SYMBOL "circle"
> COLOR 22 129 17
> SIZE 8
> END
> END
> END
> The key here is that you need to have MapServer compiled with Oracle
> Spatial support. And you can see from my data line that that I do
> standard Oracle SQL statements for building my spatial results. I'm not
> using any shapefiles in this instance. The spatial data is actually
> stored right in the database table. There are tools to import shapefiles
> into Oracle. If your data is points you can build insert statements to
> populated your geometry columns. You're probably going to want to do
> some reading up on Oracle spatial.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
>> -----Original Message-----
>> From: Bill Wordsworth [mailto:bill.wordsworth at gmail.com]
>> Sent: Tuesday, August 05, 2008 10:25 AM
>> To: Nolte, Tim; mapserver-users at lists.osgeo.org
>> Subject: Re: [MAPSERVER-USERS] How to map attribute data
>> (non-geom) from Oracle(not Spatial)?
>> This is exciting news! I am using Oracle 10g and get Oracle Locator
>> free but how do I map data from Oracle Locator? Are you doing a
>> JOIN+FILTER? Can you share a LAYER snippet from your MAP file?
>> Cheers, Bill
