[mapserver-users] Labeling
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Tue Aug 5 12:47:44 PDT 2008
Don't know if I have to correct location.
I have been successful labeling street centerlines using the ANGLE
FOLLOW in the .map File
This is being performed on a Shapefile Line feature
I also have a Polygon Feature that has a field that I am trying to
label....once again I need the text to follow the polygon
As you can see from the image the road names a following properly, but
the labels for the polygons are not following...
I tried the ANGLE FOLLOW on the Polygon and It will not draw..
I tried ANGLE [Angle] with Angle being a field name that holds Degree
values (ex 270) does the field have to be numeric?
Is there some other syntax that I have to put in the map file that will
force the text to follow the Polygon?
THANKS
STREET MAP FILE
LAYER # Maple Grove Streets Name
NAME Streets_Labels
DATA './GEOCODED_CENTERLINES2.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 6000
MINSCALE 100
LABELITEM 'STREET_NAM'
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
ANGLE FOLLOW
POSITION AUTO
MAXSIZE 10
SIZE 8
MINSIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 192
BUFFER 2
END
END
END # Maple Grove Streets Name
PARCELS MAP FILE THAT DOES NOT WORK
LAYER # Maple Grove Parcels
NAME Parcel_Labels
DATA './parcels.shp'
STATUS DEFAULT
TYPE annotation
MAXSCALE 2500
MINSCALE 100
LABELITEM 'TextString'
ANGLE [Angle]
POSITION AUTO
PARTIALS FALSE
LABELCACHE ON
CLASS
COLOR -1 -1 -1
LABEL
TYPE TRUETYPE
FONT vera_sans
MAXSIZE 8
SIZE 8
MINSIZE 2
#ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 128
BUFFER 2
END
END
END # Maple Grove Parcels
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080805/76b2ad09/attachment.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080805/76b2ad09/attachment.jpg>
More information about the MapServer-users
