[mapserver-users] Build for ArcSDE 92
Hallgren, Johan
johan.hallgren at logica.com
Wed Aug 6 09:14:13 EDT 2008
... sorry:)
Hello
As I can see the build for ArcSDE 9.2 doesn't work as expected.
The problem is that pe.lib, sde.lib and sg.lib does not include SDE version number anymore and the following line nmake.opt does not work.
SDE_LIB = $(SDE_DIR)\lib\pe$(SDE_VERSION).lib \
$(SDE_DIR)\lib\sde$(SDE_VERSION).lib \
$(SDE_DIR)\lib\sg$(SDE_VERSION).lib
I changed the version to 9.3 and
and I changed the lines to
SDE_LIB = $(SDE_DIR)\lib\pe.lib \
$(SDE_DIR)\lib\sde.lib \
$(SDE_DIR)\lib\sg.lib
that solved the problem.
/Johan
Johan Hallgren
Logica
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.hallgren at logica.com<mailto:johan.hallgren at logica.com>
http://www.logica.se<http://www.logica.se/>
Sent: den 6 augusti 2008 14:54
To: mapserver-users at lists.osgeo.org
Subject: Build for ArcSDE 92
Hello
The problem is that pe.lib, sde.lib and sg.lib does not include SDRE version numer anymore and the following line does not work.
Johan Hallgren
Logica
Pelle Bergs backe 3
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080806/b24ae5e6/attachment-0001.html
