[MAPSERVER-USERS] Mapserver bug when generating a tiled map with
MapFish
Daniel Morissette
dmorissette at mapgears.com
Wed Aug 6 10:28:19 EDT 2008
Pierre-Benoit,
Unfortunately for you, MapServer has no automated way to deal with
wrapping coordinates at the date line. If all your data is in the
[-180,180] range and you request a map for the [180,270] range then
MapServer doesn't find anything to render and returns a blank map.
You could possibly make a copy of all your data in the [180,540] range
by adding +360 to all longitude values. I don't know of any tool that
does that out of the box, but it should be easy to modify ogr2ogr to do
that for you if you are fluent in C/C++.
Another option might be to look at modifying the MapFish scripts to
handle the wrapping of coordinates at the +/-180 line and request maps
from MapServer with the correct extents.
Finally, we could possibly try to handle the wrapping in MapServer...
you could file a enhancement ticket about that. The addition sounds
simple at first, but I fear that it may be more involved than it seems.
Daniel
Pierre-Benoit Besse wrote:
> Isn't there anyone to help me with this ?
> 2008/8/4 Faldor <besse.pb at gmail.com <mailto:besse.pb at gmail.com>>
> Hi all,
> I use Mapserver with mapfish for the client side to display
> shapefiles which
> I generated using ogr2ogr.
> The problem is when I try to display a tiled layer (mapfish singleTile
> property set to 'false'). Some tiles are generated by mapserver entirely
> blank !
> After a few researches I think it is due to the fact that those
> tiles are
> extended "across" the -180°/+180° line.
> For exemple, here is the imgext property from one of the calls to
> MapServer
> which render a blank tile :
> imgext=178.59375+-1.40625+271.40625+91.40625
> Do you know of a way to fix this ?
> Regards,
> Pierre-Benoît
> http://www.nabble.com/Mapserver-bug-when-generating-a-tiled-map-with-MapFish-tp18813432p18813432.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
Daniel Morissette
http://www.mapgears.com/
