AW: [mapserver-users] How do i define my SLD inside the mapfile?
Albrecht.Weiser at hzd.hessen.de
Thu Aug 7 05:25:02 EDT 2008
Hi Bart,
what a luck that there's a workaround. Unluckily i'm not a php crack :o/ Could you please tell in a few catchwords how to apply the script?
Thanks
Albrecht
> -----Ursprüngliche Nachricht-----
> Von: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
> Gesendet: Donnerstag, 7. August 2008 09:52
> An: Weiser, Albrecht (HZD)
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] How do i define my SLD inside
> the mapfile?
> No you can't use an SLD directly in a WMS server MAP file.
> What I normally do is apply the SLD to the MAP file using a simple PHP
> script:
> #!/bin/sh
> sudo -u apache php -f $0 $*; exit $?
> <?php
> if ($argc != 4) {
> echo "Usage: applysldurl.php <input MAP file> <SLD url> <output MAP
> file>\n";
> echo "\n";
> echo "Applies the SLD url to the layers in the MAP file\n";
> echo "\n";
> exit(1);
> $oMap = ms_newMapObj($argv[1]);
> $oMap->applySLDURL($argv[2]);
> $oMap->save($argv[3]);
> echo "Output saved to $argv[3]\n";
> Best regards,
> Bart
