[mapserver-users] Hacking PROJ4...
Yvan Calcagni
yvan.calcagni at voila.fr
Fri Aug 8 07:05:25 EDT 2008
Hi everybody,
for my own developments, I set up a wms server serving data in both EPSG:4326 (wgs84) and EPSG:27582. And as these 2 projections are not based on the same meridian, the lat/lon bounding box are always false even if the EPSG:27582 BBOX goes well. So I need to override the EPSG:4326 by adding this parameter : +pm=-2.33722917. I tried to change this in the epsg file (/usr/local/share/proj/epsg) but it failed, so I tried to change this in the source file and recompile Proj4 but nothing happened too.
So, is there a way to do this, or anything else to solve this problem.
Thanks in advance for your answers.
Vanvan
____________________________________________________
Avant de prendre le volant, repérez votre itinéraire et visualisez le trafic ! http://itineraire.voila.fr/itineraire.html
