[mapserver-users] Connection to Mysql 5.0
Νίκος Παπαδάκης
nipapada at gmail.com
Tue Aug 12 11:34:59 EDT 2008
O/H Fawcett, David έγραψε:
> Nikos,
> Is it possible that MapServer is using a different ogr binary than the
> one that you are hitting from the command line. This is really a
> question for the MS4W people and not you, I guess.
> One possible reason that you are having this problem would be if
> MapServer was compiled with a different ogr than the one that you are
> hitting with your commandline and the one that MapServer is using wasn't
> compiled with MySQL support.
> I am guessing that the MS4W maintainers could prove or destroy this
> theory pretty quickly...
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Sent: Tuesday, August 12, 2008 10:00 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Connection to Mysql 5.0
> Hello to everyone!
> i have a problem in implementing the example i found in
> http://mapserver.gis.umn.edu/docs/howto/ogrmysql.
> I want to project some points on the map.
> I have created the .ovf file and the database i want to access with some
> appropriate data.
> I have also created a user and granted it with all privileges. (GRANT
> ALL ON 'dbase_name'.* to 'user'@localhost identified by 'password');
> When i use command prompt to connect to mysql with ogrinfo.exe
> everything goes fine!
> (ogrinfo.exe -al
> MYSQL:my_db,user='user',password='password',host=localhost,port=3306,tab
> les=points;).
> The results i get are information about the table contained in database
> and the contents of the selected table.
> Next i run ogrinfo.exe -al /path/to/ovf_file.ovf and again i get the
> result i expected..
> (except from the warning
> "ERROR 4: Update access not supported fow VRT datasources
> Had to open data source in read-only" which is fine according to the
> example!).
> But when i use the .ovf file through the .map file ,and after a few
> seconds,i get the message :
> /Internal Server Error/
> /The server encountered an internal error or misconfiguration and was
> unable to complete your request./
> /Please contact the server administrator, admin at local.domain and inform
> them of the time the error occurred, and anything you might have done
> that may have caused the error./
> /More information about this error may be available in the server error
> log./
> Can anyone help me becuse i'm stuck with this.
> Is it preferable to access mysql with php\mapscript instead?
> And if yes,is there any informative tutorial???
> Thank you in advance!
> Nikos Papadakis.
Well. The ogrinfo i am using is installed with mapserver
(ms4w-2.2.7-setup.exe).
and the ogrinfo.exe is in C:\ms4w\tools\gdal-ogr.
So i guess that mapserver is using the same binary...
Anyway,i hope i get an answer !!!
Thank you.
