[MAPSERVER-USERS] Problems calculating MAXSCALES
BrainDrain
paulborodaev at gmail.com
Wed Aug 13 02:16:12 EDT 2008
For calculating MIN/MAXSCALEDENOM I use openlayers ria js lib (automatic zoom
levels, supports map server layers), which is part of my web project. I have
the same question as you - howto to get current scale value with mapscript.
You can dig js code (openlayers: Map.js (getScale function)
FixedZoomLevels.js (getResolution function)) to find solution.
gisrob wrote:
> Hi Guys
> This is probably a bit of a schoolboy error, but I'm having real
> problems with my latest mapfile and MIN/MAXSCALEDENOMs.
> My mapfile contains sections like this....
> MAP
> EXTENT 235000 132715 300000 200000
> RESOLUTION 96.00
> UNITS METERS
> SIZE 500 500
> PROJECTION
> "init=epsg:27700"
> END
> LAYER
> MAXSCALEDENOM 500000
> MINSCALEDENOM 0
> NAME 'TEST'
> TILEINDEX "SHAPEFILE"
> TILEITEM "location"
> END
> Now, my basic maths suggests that if I do a shp2img on this mapfile, I
> should get a valid map. Heres my working
> minx=235000
> miny=132715
> maxx=300000
> maxy=200000
> pixels per screen meter (ppsm)= ( 100 cm / 2.54 cm ) * resolution of
> 96 = 3779.527555
> Scale = ( ( ( ( maxx - minx) * ppsm ) / imagewidth ) + ( ( ( maxy -
> miny) * ppsm ) / imageheight ) / 2
> I calculate this to be 499974.8026
> However, the map is empty. An image finally appears if I change the
> MAXSCALEDENOM value to 509631
> What schoolboy error have I made? Its all the more confusing because,
> before my MapServer 5 upgrade, this seemed to be working fine!
> Many thanks in advance
> Rob
> mapserver-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Problems-calculating-MAXSCALES-tp18926188p18957581.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
