[MAPSERVER-USERS] Problems calculating MAXSCALES
Tamas Szekeres szekerest at gmail.com
Wed Aug 13 07:07:43 PDT 2008
2008/8/13 Rob <gis at vanbooth.com>:
> If I change the (width-1) to be width, then I get scale figures that
> correspond to what I would expect, and what the ESRI GIS Clients
> hitting my WMS service seems to think that the scale should be.  From
> the dates in TRAC it certainly looks like this was changed between
> 4.8.3 and 5.0.2.
I'd prefer back out r6529 and go with a double based calculation
instead of it. However I'm not sure how this will affect the original
problem, so you should reopen this bug by pointing out the problems
with the current scale calculation you encountered.
Best regards,
Tamas
More information about the MapServer-users mailing list
