Fwd: [MAPSERVER-USERS] Problems calculating MAXSCALES
Daniel Morissette
dmorissette at mapgears.com
Wed Aug 13 10:38:11 EDT 2008
Glad to hear that Trac prevents reopening closed tickets by default.
This is not a bad thing since that ticket was closed in a previous
release and reopening tickets usually leads to confusion.
I'd suggest you open a new ticket and refer to the original one that you
were trying to reopen.
Daniel
Rob wrote:
> Sorry - didnt reply to whole list
> ---------- Forwarded message ----------
> From: Rob <gis at vanbooth.com>
> Date: 2008/8/13
> Subject: Re: [MAPSERVER-USERS] Problems calculating MAXSCALES
> To: Tamas Szekeres <szekerest at gmail.com>
> I was unable to reopen the ticket with comments - "TICKET_APPEND
> privileges are required to perform this operation"
> If someone else could reopen on my behalf, this is what I wrote for
> the comments -
> I've recently updated from 4.8.6 to 5.0.2 and fallen foul of this
> defect, where layers are not visible when I would expect them to be.
> I'm in OSGB Projection (epsg:27700) but I didn't include this
> information in my sample mapfiles, in case it was a projection related
> issue. My implementation uses mapscript rather than the cgi mapserv
> process, but I have been testing using shp2img.
> 4.8.3 Mapfile
> MAP
> EXTENT 200000 200000 266145 266145
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> RESOLUTION 96.000000
> SIZE 500 500
> STATUS ON
> TRANSPARENT TRUE
> UNITS METERS
> NAME "Base"
> IMAGEQUALITY 75
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> STATUS OFF
> END
> WEB
> IMAGEPATH "c:\tmp\"
> IMAGEURL "/"
> QUERYFORMAT text/html
> LEGENDFORMAT text/html
> BROWSEFORMAT text/html
> END
> LAYER
> MAXSCALE 500000
> MINSCALE 0
> NAME "Land"
> STATUS ON
> TRANSPARENCY 100
> TYPE RASTER
> UNITS METERS
> DATA "C:\Documents and Settings\Administrator\Desktop\gb\gbpng.tif"
> END
> END
> 5.0.2 Mapfile
> MAP
> IMAGETYPE png
> SIZE 500 500
> STATUS ON
> TRANSPARENT TRUE
> UNITS METERS
> NAME "Base"
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE "PC256"
> TRANSPARENT TRUE
> END
> PROJECTION
> "init=epsg:27700"
> END
> LEGEND
> KEYSIZE 20 10
> KEYSPACING 5 5
> LABEL
> SIZE MEDIUM
> TYPE BITMAP
> BUFFER 0
> COLOR 0 0 0
> FORCE FALSE
> MINDISTANCE -1
> MINFEATURESIZE -1
> OFFSET 0 0
> PARTIALS TRUE
> END
> POSITION LL
> STATUS OFF
> END
> WEB
> IMAGEPATH "c:\tmp\"
> IMAGEURL "/"
> END
> LAYER
> DEBUG 5
> MAXSCALEDENOM 500000
> MINSCALEDENOM 0
> NAME "Land"
> STATUS ON
> TRANSPARENCY 100
> TYPE RASTER
> UNITS METERS
> END
> END
> GBPNG.TFW
> 333.333333333
> 0.000
> 0.000
> -333.333333333
> 166.66666666
> 649833.33333333
> Any 1000x1000 image should work.
> Running shp2img against 4.8.3 will produce a valid image. Running
> shp2img against 5.0.2 does not.
> Code is currently
> center_y = (extent.miny+extent.maxy)/2.0;
> md = (width-1)/(resolution*msInchesPerUnit(units, center_y)); /*
> remember, we use a pixel-center to pixel-center extent, hence the
> width-1 */
> gd = extent.maxx - extent.minx;
> *scale = gd/md;
> For the extents in the mapfiles, this gives a scale of 500997
> Previously, using (width) instead of (width-1), we would have had 499993
> My desktop GIS product seems to agree with the calculation to result
> in 499993, judging by the bbox it requests when zooming to 1:500,000
> Full mapserver-users conversation is here -
> http://www.nabble.com/Problems-calculating-MAXSCALES-td18926188.html
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
