Fwd: [MAPSERVER-USERS] Problems calculating MAXSCALES
Rob
gis at vanbooth.com
Wed Aug 13 10:36:27 EDT 2008
Sorry - didnt reply to whole list
---------- Forwarded message ----------
Date: 2008/8/13
Subject: Re: [MAPSERVER-USERS] Problems calculating MAXSCALES
To: Tamas Szekeres <szekerest at gmail.com>
I was unable to reopen the ticket with comments - "TICKET_APPEND
privileges are required to perform this operation"
If someone else could reopen on my behalf, this is what I wrote for
the comments -
I've recently updated from 4.8.6 to 5.0.2 and fallen foul of this
defect, where layers are not visible when I would expect them to be.
I'm in OSGB Projection (epsg:27700) but I didn't include this
information in my sample mapfiles, in case it was a projection related
issue. My implementation uses mapscript rather than the cgi mapserv
process, but I have been testing using shp2img.
4.8.3 Mapfile
MAP
EXTENT 200000 200000 266145 266145
IMAGECOLOR 255 255 255
IMAGETYPE png
RESOLUTION 96.000000
SIZE 500 500
STATUS ON
TRANSPARENT TRUE
UNITS METERS
NAME "Base"
IMAGEQUALITY 75
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
END
WEB
IMAGEPATH "c:\tmp\"
IMAGEURL "/"
QUERYFORMAT text/html
LEGENDFORMAT text/html
BROWSEFORMAT text/html
END
LAYER
MAXSCALE 500000
MINSCALE 0
NAME "Land"
STATUS ON
TRANSPARENCY 100
TYPE RASTER
UNITS METERS
DATA "C:\Documents and Settings\Administrator\Desktop\gb\gbpng.tif"
END
END
5.0.2 Mapfile
MAP
IMAGETYPE png
SIZE 500 500
STATUS ON
TRANSPARENT TRUE
UNITS METERS
NAME "Base"
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT TRUE
END
PROJECTION
"init=epsg:27700"
END
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
END
WEB
IMAGEPATH "c:\tmp\"
IMAGEURL "/"
END
LAYER
DEBUG 5
MAXSCALEDENOM 500000
MINSCALEDENOM 0
NAME "Land"
STATUS ON
TRANSPARENCY 100
TYPE RASTER
UNITS METERS
END
END
GBPNG.TFW
333.333333333
0.000
0.000
-333.333333333
166.66666666
649833.33333333
Any 1000x1000 image should work.
Running shp2img against 4.8.3 will produce a valid image. Running
shp2img against 5.0.2 does not.
Code is currently
center_y = (extent.miny+extent.maxy)/2.0;
md = (width-1)/(resolution*msInchesPerUnit(units, center_y)); /*
remember, we use a pixel-center to pixel-center extent, hence the
width-1 */
gd = extent.maxx - extent.minx;
*scale = gd/md;
For the extents in the mapfiles, this gives a scale of 500997
Previously, using (width) instead of (width-1), we would have had 499993
My desktop GIS product seems to agree with the calculation to result
in 499993, judging by the bbox it requests when zooming to 1:500,000
Full mapserver-users conversation is here -
http://www.nabble.com/Problems-calculating-MAXSCALES-td18926188.html
