[mapserver-users] Re: GetCoverage request and time-idexed coverage
using postgis
Alexander Petkov
greenkov at gmail.com
Thu Aug 14 16:42:48 EDT 2008
I would like to clarify that the problem below is for using
postgis-based tileindex for WCS GetCoverage requests (WMS GetMap
requests work fine).
I did some more poking around. In particular, I tried to use the
postgis-based tileindex, but this time through the OGR driver:
LAYER
STATUS ON
NAME "time_idx"
TYPE POLYGON
DATA "select * from sometable"
DEBUG 5
METADATA
"wms_srs" "EPSG:2613"
"wms_extent" "-2050500.000 -2136500.000 2536500.000 752500.000"
"wms_title" "TIME INDEX for departure from average images"
END
CONNECTION "PG:dbname=blah user=blah host=blah"
CONNECTIONTYPE ogr
EXTENT -2050500.000 -2136500.000 2536500.000 752500.000
PROJECTION
"init=epsg:2163"
END
END
This now seems to work, except that looks like I explicitly need to
explicitly specify each and every time position in my raster layer:
"wcs_timeposition" "2000-01-06,....,2005-12-27"
Does anyone use WCS for GetCoverage requests with a postgis-based
tileindex, either through a postgis or OGR connection?
Thanks in advance,
Alex
